Hi.
Currently looking for some advice, I have been having frequent drop outs for the past few weeks (started just before Christmas maybe). The SH3 will just seem to randomly lose internet access, then usually the WIFI light will come on solid green and the Internet light will be flashing green.
While this is happening I will lose external access, and also intermittently lose local access to the SH3 (runing internal and external ping to monitor the connection).
If I am able to login to the hub while this is happening, I can see on the Home page it reports either:
Internet: Access Denied
or
Internet: Partial Service(US Only)
Once this happens I find that sometimes a reboot of the hub will resolve it (but sometimes not).
The SH3 network logs show: the following when the issues are ocuring:
22/01/2021 14:45:14 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/01/2021 14:45:12 | Warning! | B-INIT-RNG Failure - Retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/01/2021 14:40:13 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/01/2021 14:40:12 | Warning! | B-INIT-RNG Failure - Retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/01/2021 14:35:15 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/01/2021 14:35:14 | Warning! | B-INIT-RNG Failure - Retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/01/2021 14:29:7 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/01/2021 14:28:39 | Warning! | B-INIT-RNG Failure - Retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/01/2021 14:22:42 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/01/2021 14:22:39 | Warning! | B-INIT-RNG Failure - Retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/01/2021 14:18:18 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/01/2021 14:18:17 | Warning! | B-INIT-RNG Failure - Retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/01/2021 14:13:25 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/01/2021 14:13:22 | Warning! | B-INIT-RNG Failure - Retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/01/2021 14:07:42 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/01/2021 14:07:40 | Warning! | B-INIT-RNG Failure - Retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/01/2021 14:04:3 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/01/2021 14:04:0 | Warning! | B-INIT-RNG Failure - Retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/01/2021 13:56:47 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
The connection has come back online again today since these logs were generated, but I have noticed the DS Power levels might be a little high over 10 (Power dBmV):
1 | 203000000 | 12.6 | 40 | 256 qam | 9 |
2 | 211000000 | 12.4 | 40 | 256 qam | 10 |
3 | 219000000 | 12.4 | 43 | 256 qam | 11 |
4 | 227000000 | 12 | 40 | 256 qam | 12 |
5 | 235000000 | 11.8 | 40 | 256 qam | 13 |
6 | 243000000 | 11.6 | 40 | 256 qam | 14 |
7 | 251000000 | 11.1 | 40 | 256 qam | 15 |
8 | 259000000 | 11.5 | 40 | 256 qam | 16 |
9 | 267000000 | 11.5 | 40 | 256 qam | 17 |
10 | 275000000 | 11.4 | 40 | 256 qam | 18 |
11 | 283000000 | 11.4 | 40 | 256 qam | 19 |
12 | 291000000 | 11.1 | 40 | 256 qam | 20 |
13 | 299000000 | 11.4 | 40 | 256 qam | 21 |
14 | 307000000 | 11.3 | 40 | 256 qam | 22 |
15 | 315000000 | 11.6 | 40 | 256 qam | 23 |
16 | 323000000 | 11.9 | 40 | 256 qam | 24 |
17 | 331000000 | 11.5 | 40 | 256 qam | 25 |
18 | 371000000 | 11.9 | 40 | 256 qam | 26 |
19 | 379000000 | 11.6 | 40 | 256 qam | 27 |
20 | 387000000 | 11.5 | 40 | 256 qam | 28 |
21 | 395000000 | 11.1 | 40 | 256 qam | 29 |
22 | 403000000 | 10.9 | 40 | 256 qam | 30 |
23 | 411000000 | 10.8 | 40 | 256 qam | 31 |
24 | 419000000 | 10.5 | 40 | 256 qam | 32 |
1 | Locked | 40.9 | 4 | 0 |
2 | Locked | 40.9 | 7 | 0 |
3 | Locked | 43.3 | 6 | 0 |
4 | Locked | 40.9 | 6 | 0 |
5 | Locked | 40.9 | 7 | 0 |
6 | Locked | 40.9 | 7 | 0 |
7 | Locked | 40.9 | 2 | 0 |
8 | Locked | 40.9 | 7 | 0 |
9 | Locked | 40.9 | 10 | 0 |
10 | Locked | 40.9 | 7 | 0 |
11 | Locked | 40.9 | 4 | 0 |
12 | Locked | 40.3 | 10 | 0 |
13 | Locked | 40.3 | 19 | 0 |
14 | Locked | 40.9 | 7 | 0 |
15 | Locked | 40.9 | 7 | 0 |
16 | Locked | 40.3 | 21 | 0 |
17 | Locked | 40.9 | 2 | 0 |
18 | Locked | 40.9 | 0 | 0 |
19 | Locked | 40.9 | 5 | 0 |
20 | Locked | 40.9 | 1 | 0 |
21 | Locked | 40.9 | 7 | 0 |
22 | Locked | 40.3 | 5 | 0 |
23 | Locked | 40.9 | 3 | 0 |
24 | Locked | 40.9 | 1 | 0 |
Could this be part of the reason I am having issues?
I have spoke with Virgin support this week, was told they would be sending me a new router today, however this hasnt arrived and now they tell me it should arrive by Tuesday next week, but I am not sure if this will make much difference.
Can anyone advise?
Kind regards
Matt
