  • 45
talcyh
Router on going problem
On going router problems.
Modem/router has again reset itself to factory settings again yesterday, losing passwords, SSID’s etc. This is in spite of the engineer visit last week which clearly hasn’t fixed the problem.  What next please?
Now got flashing green lights and no internet
Malcolm Harris
  • 13.22K
  • 1.01K
  • 3.08K
Re: Router on going problem
maybe one problem maybe two - flasking green light is extenal fault but that [normally] would not cause hub to reset
what did the tech do last week
post some info
it might be meaningless until internet comes back but post it all the same then post it again when internet returns
log into hub3 - 192.168.0.1 [or 192.168.100.1 if in modem mode] - DON'T SIGN IN, click - click router status [centre of screen] - and post the downstream and upstream figures - to see those press on the grey buttons/boxes labeled - upstream - downstream
if its an earlier hub button is top right
____________________
Tony
  • 45
talcyh
Thanks Tony.  Turns out ther is an outage in the area hence the green lights.
Still does not explain the router problem. The engineer changed some cables and checked the signal strengths, declaring them fine.  Beyond that, monitor and get back if problem persists.
Can’t connect to hub ATM, probably due to outage.  Will add the figures when access returns.
Malcolm
