LouisN
Just joined
Replacement hub required.
Good afternoon,
I have a damaged hub and require a replacement. How do I go about getting a replacement for this?
  • 13.25K
  • 1.01K
  • 3.08K
Re: Replacement hub required.
you can ring but no idea what CS will do - they are likely to want o run tests and even then may not get to sending you one
or you can wait here for VM and they will sort it
____________________
Tony
  • 1.37K
  • 74
  • 97
Hi LouisN,
Thanks for your post and welcome to our community 🙂
Have you been able to get any help with this since your post?
Can you confirm how the hub is damaged?
Let me know if you still need help.
Alex_Rm
