Paxo12
Remote working with tv and soundbar
Can I use my v6 remote to work the tv and soundbar at the same time as I can only get one or the other to work not both
  • 19.32K
  • 1.68K
  • 4.23K
Re: Remote working with tv and soundbar
doubtful, could get a universal remote so can do that
Click to learn more about VIP
Use Kudos to say thanks
  • 4.7K
  • 319
  • 790
Roger_Gooner
Superstar
Only one is allowed. Pair with the soundbar to change volume.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
  • 10.12K
  • 749
  • 2.12K
Set it to the TV first and then the sound bar, you can have both
  • 4.7K
  • 319
  • 790
Roger_Gooner
Superstar
You can pair the TV and then the the soundbar but the volume/mute commands will get overridden for the soundbar are will therefore no longer work for the TV.
  • 149
  • 21
  • 37
EightBall
Superfast
Re: Remote working with tv and soundbarbs
You can absolutely have it on both. Do the TV first and then the sound bar.
