  • 31
R3dbvll
Message 1 of 5
Red light on my Hub 3 after upgrade to 350Mb/s
HI all,
I've been on the Vivid 150 service for some time now, and have a SuperHub 3.
After talking to a rep at Virgin today (about lowering our phone bill as it happens), he upgraded my broadband to the 350Mb/s service.   All is good, it so far seems reliable and delivers good speeds.
However, the Hub 3 (which is and always has been in modem mode), now has a red light at the bottom, rather than the green it used to have.  Everything works fine, no faults, the unit is certainly not over heating.
Is this related to the change of speed?
  • 12.96K
  • 991
  • 2.98K
Message 2 of 5
Re: Red light on my Hub 3 after upgrade to 350Mb/s
the light in modem mode should be magenta - red to you and me - in normal [router mode] it should be white - a green light at the bottom usually means there is a fault
make of that what you want - so what you have is correct - what the green light was trying to tell you before i have no idea
____________________
Tony
  • 31
R3dbvll
Message 3 of 5
Hi Tony,
I'll take that as an answer!  According to Virgin's own, red is supposed to mean overheating.
I tried an experiment and switched mode to router, and sure enough the light changed to a bright green (again different to the green it was before - getting weird).
All is fine however - I have no idea how anyone could distinguish the colour as magenta!
  • 3.4K
  • 192
  • 553
chenks
Wise owl
Message 4 of 5
it looks more deep pink to me (which is what magenta technically is), no where near being red though!
Magenta (/məˈdʒɛntə/) is a color that is variously defined as purplish-red, reddish-purple, purplish, or mauvish-crimson.
  • 31
R3dbvll
Message 5 of 5
Yes I supposed it is a deep pink really. What I need is an actual red light on the device to compare it to...
