alana-b
Quickstart installation wrong wall connector
I have just received my quick start box for broadband having waited over a week from when it was meant to be delivered only to find that our doesn't fit the connector I have on my wall. I was told multiple times when I ordered that I would be able to use the quickstart.
The only reason I went with virgin was because of the quick start option, in the time I've been waiting I could have had an engineer from another provider come out and install.
I am currently on the phone to vm trying to get it sorted, not having much luck - have already been cut off once when I eat meant to be being transferred to the "pre install" team.
I can't work until this is sorted, I already regret going with vm and I haven't even tried the broadband yet.
Has anyone got any ideas of what I can do short of cancelling my contract completely and going with someone else?
nodrogd
  • 16.17K
  • 1.87K
  • 3.82K
Re: Quickstart installation wrong wall connector
The Quick Start ordering pages tell you what you should have to connect too. The only info VM has is that a previous customer at the address has used services. They are not responsible for, or will have any knowledge of a previous occupant removing the internal sockets or wiring you need to use since that installation took place.
So if you dont have either of the sockets below you will require a manned install:
Virgin coax outletVirgin coax outletNew Euro outletNew Euro outlet
Virgin BB TV Landline. Freeview/Freesat HD, Virgin Mobile, Tesco Mobile. Cable customer since 1993
Ryan_N
  • 1.94K
  • 99
  • 158
Hi alana-b,
Thank you for your post.
Sorry for the experience you've had here. I can see from your account that you've spoken with the team over the phone regarding this - also have a technician appointment booked. Can you let me know how things are going?
Cheers.
Ryan_N - Forum Team - https://community.virginmedia.com/t5/custom/page/page-id/WelcomeGoodFolk
alana-b
Hi Ryan,
Having been on the phone to vm for over 2 hours and eventually getting an engineer out it seems to have been resolved.
