Message 1 of 7
Power light flashing green with QuickStart
Hello, I was wondering if someone on here can help. I ordered Virgin Broadband with QuickStart. I have a solid green WiFi light and a blinking green power light. whenever I try to get support online or on the phone I just get redirected to the setup guide. They won’t answer the phone or reply to my text messages.It feels like Virgin have take my money, sold me a product that isn’t working and done a runner; rather than being available to provide support to get its working. I understand call centres are down because of covid but if Virgin can’t sell a product and provide adequate support, perhaps Virgin shouldn’t sell the product until call centres can open again. I’m hoping that someone here can help so that I don’t have to cancel the package and go somewhere else. I was really excited to be with Virgin. Thank you
  • 960
  • 69
  • 134
Well-informed
Message 2 of 7
Re: Power light flashing green with QuickStart
Did the activate the router?
Message 3 of 7
Hi! Thank you so much for your response. I had a text message saying that they’ve sent the signal and I’m ready to set everything up
  • 14.91K
  • 1.17K
  • 3.48K
Message 4 of 7
try them again for activation - they should try again - if that does not work or you are convinced it was done the first time then you have a cable fault i would guess
that can be you - do you have the internal box and is it in good condition - if it is trace the cable back to the external box and again is that ok - post some photos - if again you think everything is ok you need a tech - the cable in the cab could be disconnected
add as much info as you can and VM here should get a tech booked
____________________
Tony
Message 5 of 7
Thank you very much for your help
I have a suspicion it’s the old Virgin box on the wall that was installed before we moved in 4 years ago.
Ideally, I’d like to be able to contact Virgin to confirm that they sent the signal out or to resend it but they won’t pickup. I was on hold for an hour yesterday before the call dropped.
I wouldn’t want to get an engineer out for no reason, but it doesn’t seem like I’d be able to contact them to get hold of them anyway. Maybe I’ll try the cancellation route. They might pickup
all the cables are fine though and checked. Perhaps I’ve got a funky hub?
  • 14.91K
  • 1.17K
  • 3.48K
Message 6 of 7
why do you suspect the internal box - is it damaged - it has an isolator in it and that may be faulty but its rare i think
post a few photos - if possible take the cover off and see if the isolator is connected - again post some photos
Tony
Message 7 of 7
Hi tony, thank you so much for your help. I finally managed to get someone on the phone and they’re sending out an engineer next week!
fantastic service when you can get through and this community is unlike anything I’ve experienced with a utility company before!
its amazing!
i’ll post an update after the engineer has come to share what the issue was so that it might help other people or confirm your suspicions 🙂
thank you
