RR-IT-GUY
  • 154
  • 8
  • 7
Superfast
Power Levels wrong Ethernet ports on hub not working on every boot with DHCP Server fault
 need an engineer to correct power levels as they are wrong and i also need a new hub as ethernet ports randomly stop working and start assigning IP addresses that are out of 192.168.0.1-256.
I do use some Mac address rules however have done so for a long time.
139000000
Locked
Ranged Upstream Channel (Hz)
32600000
Locked
Provisioning State
Online
113900000018.338256 qam1
214700000017.638256 qam2
315500000017.438256 qam3
416300000017.538256 qam4
517100000017.138256 qam5
617900000016.938256 qam6
718700000016.638256 qam7
819500000016.538256 qam8
92030000001638256 qam9
1021100000015.638256 qam10
1121900000015.638256 qam11
1222700000015.438256 qam12
1323500000015.138256 qam13
142430000001538256 qam14
152510000001538256 qam15
1625900000015.438256 qam16
1726700000015.638256 qam17
1827500000015.638256 qam18
1928300000015.938256 qam19
202910000001638256 qam20
2129900000016.338256 qam21
223070000001638256 qam22
233150000001638256 qam23
2432300000016.338256 qam24
1Locked38.6360
2Locked38.9290
3Locked38.9260
4Locked38.6300
5Locked38.9360
6Locked38.9110
7Locked38.6160
8Locked38.9170
9Locked38.6190
10Locked38.9160
11Locked38.9180
12Locked38.6290
13Locked38.6260
14Locked38.6430
15Locked38.6620
16Locked38.6420
17Locked38.6250
18Locked38.6240
19Locked38.9250
20Locked38.9230
21Locked38.6270
22Locked38.9180
23Locked38.6270
24Locked38.9260
RR-IT-GUY
  • 154
  • 8
  • 7
Superfast
Re: Power Levels wrong Ethernet ports on hub not working on every boot with DHCP Server fault
13260000034512032 qam11
23940000034512064 qam8
34620000034.8512064 qam7
42580000033.5512064 qam12
1ATDMA0050
3ATDMA0030
4ATDMA0040
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt057+voc-b.cm
SFID673274
Max Traffic Rate117000047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID673273
Max Traffic Rate10500047
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
30/01/2021 07:50:20criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/01/2021 17:50:46noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/01/2021 03:11:1criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/01/2021 03:10:30criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/01/2021 03:09:33criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/01/2021 03:05:21Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/01/2021 03:05:17criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/01/2021 03:05:17Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/01/2021 03:05:16Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/01/2021 21:01:29criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/01/2021 18:48:36ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/01/2021 23:36:36noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/01/2021 03:45:29criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/01/2021 20:01:41ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/01/2021 19:44:5criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/01/2021 15:27:52noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/01/2021 18:56:47criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/01/2021 04:35:35ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/01/2021 09:03:58criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
RR-IT-GUY
  • 154
  • 8
  • 7
Superfast
Here is a BMQ
BMQ LIVE
RR-IT-GUY
  • 154
  • 8
  • 7
Superfast
Just wanted to clarify on the DHCP issue i have done pinhole reset which is what caused the problem in the first place as requested by the team as my area has a congestion issue which is not fixed.
