JLaurence
Pairing the remote with the telly for volume control
Hi, All
My Virgin remote was behaving weirdly, so I went through the step-by-step guide and re-set it and re-paired it with the TiVo box. It's now working fine.
However, when I re-set the remote, it stopped pairing with the telly, so I can't control the volume or mute button with the Virgin remote.
Is there some secret series of buttons to press to make it pair with the television's volume control?
Thanks!
jb66
  • 12.27K
  • 911
  • 1.78K
Re: Pairing the remote with the telly for volume control
Yes it needs to be programmed to the tv to control the volume, what brand of tv do you have?
JLaurence
Hi, thanks for the quick reply. It's a Sony Bravia, about 10 years old.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Use the TV Remote Home > Help & Settings > Help > Virgin TV > Programme Your Remote > OK
Follow them there instructions.
JLaurence
Ta very much!
Alby41
  • 20
I had little success getting the volume and muting to operate with the remote control ,, all else paired fine.
So I found "Baz" on You tube who shewed how to do pair the remote easily , mine worked 1st go , now all is
good ...have a look at him here ...... good luck.
https://www.youtube.com/watch?v=UxwVQodTiv0
