on 07-10-2021 22:08
we moved into this flat recently and were provided with a QuickStart setup as the flat had VM at some time before. We’re stuck at the step where we’re supposed to connect the cable with the red “wall socket” label to the VM wall socket (pictured - sorry, seems to be 90 degrees rotated bere). It doesn’t connect.
There was a kind of “terminator” (?) cap screwed onto the wall socket which we unscrewed, but we still can’t connect the cable end. Any advice on what we’re not getting?
Michael
Answered! Go to Answer
07-10-2021 22:42 - edited 07-10-2021 22:49
Looks like half the terminator cap is still lodged inside the socket. Not your fault, It should have come out along with the rest of the terminator cap, the manufacturers of the cap haven't used enough solder.
You need to grip the centre pin and pull it out. Do it carefully keep the other hand on the wall socket dont want to pull the whole thing off the wall.
on 07-10-2021 22:30
Hi there, I can't see the photos yet, however...
If you removed a terminator cap from the socket, then you should be able to plug the Hub's cable straight in.
The cable they have sent you, does it have a screw type connector with a single pin in the centre?
Does the wall socket have a pin in the centre?
on 07-10-2021 22:41
thanks for replying! While the photos are approved on the forum here, I've also uploaded it here:
I assume this is what you mean by pin in the centre of the wall socket?
The cable itself seems not to be screw type but does have a single pin as far as I can tell. See:
07-10-2021 23:00 - edited 07-10-2021 23:00
Amazing, thank you - that did the job. I didn't have the courage to pull out that centre pin without someone telling me that this is the right thing to do... Now happily writing this post from my functioning VM connection. Thanks again for the very fast guidance.
on 07-10-2021 23:43
Good to hear you're up and running, enjoy your connection!
on 10-10-2021 09:48
Hi @mbimmler,
Apologies for the delayed response here. I am sorry that you had a little bit of an issue with the wall socket, but I'm so glad to hear that you've been able to get this resolved thanks to the help of @asim18.
Please do let us know if there's anything more that we can assist you with.
