  • 19
ciccone
Message 1 of 5
Need help with external box cables
Hello, this is a tricky problem too explain. I have been having terrible connection issues with drop outs and low speeds. After three engineer visits yesterday the engineer finally worked out that the issues is from the street to my box. He thinks that the signal has been split with the neigbour and this is the issue, so he needed to access the external box, however the box is now in an unsafe location and may not be able to access. So I got up on the roof and opened the box and the picture is what I found , I’ve now tried to disconnect on of the cables to see if that would help but it didn’t! Can anyone advise on what I need to do
thanks
71574E1F-F6F6-4AEB-9787-E3379E40F213.jpegExternal box with a splitter61689C65-AED0-4E92-B736-5FACC9B5740A.jpeg
  • 19.32K
  • 1.68K
  • 4.23K
Message 2 of 5
Re: Need help with external box cables
how on earth did the box end up on the roof?, are you in a block of flats?,
can you repost your new downstream, upstream, and network log. having a splitter is perfectly fine if done correctly, since the box in the street is just a giant splitter
Click to learn more about VIP
Use Kudos to say thanks
  • 3.65K
  • 201
  • 608
chenks
Community elder
Message 3 of 5
only one piece of advice - do not touch or do anything with the box or cabling.
  • 4.7K
  • 319
  • 788
Roger_Gooner
Superstar
Message 4 of 5
If the cable is shared with a neigbour you need to look for the neighbour's box and the cable connected to both boxes. Even if this has been done it doesn't necessarily mean that you should have a problem as what matters is whether the signal is strong enough for two homes as splitting always results in signal loss.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
  • 6.23K
  • 481
  • 1.03K
Hero
Message 5 of 5
One of the outputs of the splitter is open without a terminator, so there is possibly of noise ingress. In fact there is no need for a splitter as one one the cables has been removed, just need a joiner.
