Tasher97
Message 1 of 9
Need ethernet cable/port in bedroom but hub downstairs
Hi, as title says... I need a secure connection upstairs, my internet connection is tempormental, I have to ring up Virgin constantly for them to fix it. I want to connect my laptop and console through a wired connection- as wifi is too weak.
I don’t want to buy a seperate WIFI router- as my issue is upload speed. So wired connection is better.
Would Virgin come put a internet port upstairs? I don’t know how to go about this and i’m not happy drilling through walls.
  • 10.12K
  • 748
  • 2.11K
Message 2 of 9
Re: Need ethernet cable/port in bedroom but hub downstairs
That's not a service Virgin offer, you might have to contact a local handyman
Click to learn more about VIP
Use Kudos to say thanks
  • 4.62K
  • 312
  • 773
Roger_Gooner
Superstar
Message 3 of 9
Find a local electrician to run the cat 5e or cat 6 Ethernet cable from the hub to your bedroom, drilling and floorboard lifting will be needed. I recommend termination at an RJ45 wall plate. You can then plug in a network switch (see my sig as an example) and connect your laptop and console to the ports on the switch. Should you need good WiFi in your bedroom, which is quite likely as the WiFi from the hub is weak, a wireless access point can also be connected to the switch.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
  • 3.65K
  • 201
  • 608
chenks
Community elder
Message 4 of 9
and make sure it's an electrician that knows how to propertly run network cable and terminate it properly.
some (maybe most) wouldn't have the foggiest.
  • 1.27K
  • 68
  • 118
dnpark38
Knows their stuff
Message 5 of 9
Think cat 6 as replaced the cat 5e and even one to replace cat 6, might be an additional letter.
( Think it might be to the better TV standards the 4K and 8K)
"VM 50 Mps Broadband and anytime phone."
  • 11.8K
  • 1.08K
  • 2.56K
griffin
Message 6 of 9
One thing you can look at is if there are any pipework (water \ heating) running between floors you can run the ethernet cable alongside.
Otherwise, someone needs to get a drill out.
Another solution would be powerline adapters that use your home's electrical circuiits as a wired connection back to the hub.
This is far more convenient, but not quite as robust as a wired connection as they can be affected by noise on your mains. but work well for a lot of people.
  • 9.13K
  • 946
  • 1.43K
Message 7 of 9
Best suggestions are above. But as an alternative you could consider a pair of "powerline adapters" to connect your Hub to your equipment upstairs with short Cat6a cables. My lad is an internet gamer and refuses to use wifi and he has his PC & xbox wired up in this way and has never once complained. It requires that the two electrical circuits are actually the same or that they pass through the same consumer unit (fuse box) and are not on RCD extensions.
EDIT: griffin beats me to it again Smiley Happy
  • 13.12K
  • 1K
  • 3.05K
Message 8 of 9
running the cable internally is hard work - hole though external wall downstairs - up one level and hole through bedroom wall - if you want to do it with a premade cable [which is easiest for diy] then a 12mm hole will allow you to pass the cable end through - cement or silicone to seal the hole - clip cable to external wall
smaller hole - about 6mm if you are going to use face plates
____________________
Tony
  • 6.15K
  • 471
  • 1.02K
Hero
Message 9 of 9
Make sure you get two Ethernet cabled installed. The extra cost of the cable is negligible and if in the future you ever have trouble with the original cable, you will have a spare to use. The cost is in the work, not in the cable.
