Have you tried new batteries?
At least try taking the existing batteries out then putting them back in which may 'reset' the remote. Make sure you put them in correct way round.
If that doesn't work try rebooting the box
I know a bit about Wi-Fi, Telecoms, and TV as I used to do it for a living but I'm not perfect so don't beat me up... If you make things you make mistakes!
