  • 5
AwesomeWalls74
Message 1 of 10
M200 Speed - Only installed 03-July less than average download speed already!
Screenshot (13).pngScreenshot (3).pngScreenshot (5).pngScreenshot (7).pngScreenshot (9).pngScreenshot (11).png
  • 2.81K
  • 142
  • 419
jpeg1
Trouble shooter
Message 2 of 10
Re: M200 Speed - Only installed 03-July less than average download speed already!
The one piece of information you haven't given is how you are measuring the speed. The only valid measurement is with a suitable device (1Gb ethernet connection) wired to the hub with a cat5e or better cable.
A WiFi connection may be less, depending upon your local conditions.
  • 5
AwesomeWalls74
Message 3 of 10
Hi,  it's via a wired connection - assuming cat5e.  I used the speedtest.net site and had lows of 60's and highs of 90's.
  • 2.81K
  • 142
  • 419
jpeg1
Trouble shooter
Message 4 of 10
Are you sure that the device you are using has 1Gb ethernet and not 100Mb?
Was there any other device connected during the measurement? If in doubt set the Hub to modem mode and measure again.
The signal levels are OK but there is some noise present which may be affecting things.
Go to thinkbroadband.com and set up a BQM to monitor the connection. Post the result here after a day or so.
  • 6.23K
  • 481
  • 1.03K
Hero
Message 5 of 10
Post your upstream levels and network log. Sometimes the upstream gives a better clue if there is noise on the circuit.
  • 5
AwesomeWalls74
Message 6 of 10
Thanks, I will check which type of network cable I was using and re-test on modem mode.
From a quick Google I need at least 5e.
  • 2.81K
  • 142
  • 419
jpeg1
Trouble shooter
Message 7 of 10
You must also check that the test device has a 1Gb ethernet port.
  • 5
AwesomeWalls74
Message 8 of 10
Checked the cable and its 5e. How do I confirm my laptop has a 1Gb port?
  • 5
AwesomeWalls74
Message 9 of 10
Think I identified the laptop I was originally using had a 10/100 ethernet port.  Changed to a 1GB port and got the following results ... 🙂
  • 2.81K
  • 142
  • 419
jpeg1
Trouble shooter
Message 10 of 10
Your graphic hasn't been cleared yet.  What did you measure?
