andrew_rowlands
  • 15
Message 1 of 29
Latency Issue - Hub 4.0
Hey,
I'm currently having an issue where I'm getting constant ping spikes through my network. I've been down pretty much every avenue that my googling can take me and I've still had no joy.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/5b584dc4b111081cb69f1633428e34072e...
This is what my ping has been looking like for the past few weeks.
Been on the phone to support who've tried resetting my line from their end and I'm still running into the same issue. Pinging googles DNS servers over 40 pings gives me typically 18ms minimum and over 100ms maximum (it hit 200ms at one test).
I've tried the hub in modem mode and I'm still running into the same issue.
Has anyone else had something like this happen? Any ideas on the best way to get this resolved would be massively appreciated!!
Thanks!
Tags (2)
paultechy
  • 19.76K
  • 1.74K
  • 4.1K
Message 2 of 29
Re: Latency Issue - Hub 4.0
Would need to check the signal levels if could go to http://192.168.0.1 or if using modem mode http://192.168.100.1 clicking router status top right or bottom of page depending on hub [no need to login - depending on hub] and if could copy/paste the downstream, upstream, network log, don't worry about the formatting we can easily read it.. try and avoid using screen shots..
andrew_rowlands
  • 15
Message 3 of 29
Thanks for getting back to me! Hopefully these make a little more sense to you than they do to me!
3.0 Downstream channels
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
4
163000000
4.400002
37.636276
QAM256
4
1
139000000
5.500000
36.609653
QAM256
1
2
147000000
5.300003
37.355988
QAM256
2
3
155000000
4.800003
36.609653
QAM256
3
5
171000000
4.300003
37.355988
QAM256
5
6
179000000
3.700001
37.636276
QAM256
6
7
187000000
3.599998
37.355988
QAM256
7
8
195000000
3.200001
37.636276
QAM256
8
9
203000000
2.799999
37.355988
QAM256
9
10
211000000
2.500000
37.636276
QAM256
10
11
219000000
1.799999
37.355988
QAM256
11
12
227000000
1.599998
37.355988
QAM256
12
13
235000000
1.000000
37.355988
QAM256
13
14
243000000
0.599998
37.636276
QAM256
14
15
251000000
0.500000
37.636276
QAM256
15
16
259000000
-0.200001
37.636276
QAM256
16
17
267000000
-0.099998
37.636276
QAM256
17
18
275000000
-0.200001
37.355988
QAM256
18
19
283000000
-0.500000
37.355988
QAM256
19
20
291000000
0.700001
37.636276
QAM256
20
21
299000000
0.700001
37.636276
QAM256
21
22
307000000
0.400002
38.605377
QAM256
22
23
315000000
0.400002
38.605377
QAM256
23
24
323000000
0.900002
37.636276
QAM256
24
25
331000000
2.000000
38.605377
QAM256
25
26
339000000
1.099998
38.605377
QAM256
26
27
347000000
0.400002
38.605377
QAM256
27
28
355000000
0.500000
38.605377
QAM256
28
29
363000000
0.299999
38.605377
QAM256
29
30
371000000
0.200001
37.636276
QAM256
30
31
379000000
0.200001
38.605377
QAM256
31
Channel
Lock Status
RxMER (dB)
Pre RS Errors
Post RS Errors
4
Locked
0
0
0
1
Locked
100834821
0
0
2
Locked
100179953
0
0
3
Locked
96707472
0
0
5
Locked
100212636
0
0
6
Locked
100414807
0
0
7
Locked
3131644332
0
0
8
Locked
90245838
0
0
9
Locked
77336458
0
0
10
Locked
76135840
0
0
11
Locked
75345639
0
0
12
Locked
74736488
0
0
13
Locked
75712245
0
0
14
Locked
75894357
0
0
15
Locked
75062645
0
0
16
Locked
56018842
0
0
17
Locked
55286884
0
0
18
Locked
56214785
0
0
19
Locked
56723324
0
0
20
Locked
55379139
0
0
21
Locked
55290313
0
0
22
Locked
54757047
0
0
23
Locked
56009175
0
0
24
Locked
128545607
0
0
25
Locked
125827212
0
0
26
Locked
126890703
0
0
27
Locked
128999645
0
0
28
Locked
125860757
0
0
29
Locked
123280627
0
0
30
Locked
123297873
0
0
31
Locked
1953143732
0
0
3.1 Downstream channels
Channel
Channel Width (MHz)
FFT Type
Number of Active Subcarriers
Modulation (Active Profile)
First Active Subcarrier (Hz)
159
96
4K
1880
QAM2048
759
Channel ID
Lock Status
RxMER Data (dB)
PLC Power (dBmV)
Correcteds (Active Profile)
Uncorrectables (Active Profile)
159
Locked
-13.3
814123575
0
andrew_rowlands
  • 15
Message 4 of 29
3.0 Upstream channels
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
46200000
44.520599
5120 KSym/sec
64QAM
3
2
39400000
43.770599
5120 KSym/sec
64QAM
4
3
53700000
45.270599
5120 KSym/sec
64QAM
2
4
60300000
45.770599
5120 KSym/sec
64QAM
1
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
US_TYPE_STDMA
0
0
0
0
2
US_TYPE_STDMA
0
0
0
0
3
US_TYPE_STDMA
0
0
0
0
4
US_TYPE_STDMA
0
0
0
0
Time
Priority
Description
Sat 31/10/2020 16:58:34
3
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 31/10/2020 16:58:36
6
CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 31/10/2020 16:58:37
5
Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 31/10/2020 16:58:40
6
CM-STATUS message sent. Event Type Code: 1; Chan ID: 7; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
5
Sat 31/10/2020 16:58:53
6
CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 02/11/2020 17:50:59
4
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
6
DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 02/11/2020 20:25:37
6
CM-STATUS message sent. Event Type Code: 5; Chan ID: 31; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 03/11/2020 16:34:26
3
No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 05/11/2020 05:28:23
6
CM-STATUS message sent. Event Type Code: 23; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 06/11/2020 05:50:59
4
6
Sun 08/11/2020 13:24:51
3
Mon 09/11/2020 17:50:59
4
6
Thu 12/11/2020 05:27:34
6
Fri 13/11/2020 05:50:59
4
Fri 13/11/2020 05:51:00
6
Sun 15/11/2020 14:14:36
3
Sun 15/11/2020 20:26:50
6
CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 16/11/2020 17:51:00
4
6
Thu 01/01/1970 00:01:18
3
Mon 16/11/2020 18:10:20
5
MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 16/11/2020 19:26:50
3
Mon 16/11/2020 19:26:53
3
Mon 16/11/2020 19:26:56
5
3
Mon 16/11/2020 19:27:04
6
CM-STATUS message sent. Event Type Code: 1; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
3
Mon 16/11/2020 19:27:10
6
CM-STATUS message sent. Event Type Code: 5; Chan ID: 16; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 16/11/2020 19:27:11
3
Mon 16/11/2020 19:27:17
6
CM-STATUS message sent. Event Type Code: 21; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 16/11/2020 19:27:18
3
Mon 16/11/2020 19:27:19
3
Ranging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
3
Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 16/11/2020 19:27:20
3
Mon 16/11/2020 19:27:41
3
3
3
Mon 16/11/2020 19:27:43
3
3
3
Mon 16/11/2020 19:27:45
3
3
3
Mon 16/11/2020 19:28:40
5
Tue 17/11/2020 13:49:04
3
Tue 17/11/2020 19:37:36
5
If you need anything else let me know and I'll grab it! Thank you for your time!
Anonymous
Not applicable
Message 5 of 29
Your DOCSIS 3.1 channel has some issues:
  • The QAM value should be 4096
  • The power level is too low at -13.3dBmV
Channel
Channel Width (MHz)
FFT Type
159
96
4K
1880
QAM2048
759
Channel ID
Lock Status
RxMER Data (dB)
PLC Power (dBmV)
159
Locked
-13.3
814123575
0
This could be the main items causing your issues, and could also explain the terrible BQM.
andrew_rowlands
  • 15
Message 6 of 29
Thanks for having a look Carl!
Is this something that I can through my hub settings?
Anonymous
Not applicable
Message 7 of 29
It requires an engineer visit to investigate further.
andrew_rowlands
  • 15
Message 8 of 29
No trouble, thanks for getting back so quickly!
I'll give support a ring and see if I can get someone around to have a look at it (fingers crossed!!)
andrew_rowlands
  • 15
Message 9 of 29
Just a follow on from the above issues. Spent a few hours of my week on hold to virgin trying to convince them I had an issue with my connection to be told there was no issue and there was nothing they could do. I eventually got told that I shouldn't have upgraded to a hub 4.0 because I wasn't on a gigabit connection and that this was my issue (also that it was my fault for upgrading to a hub 4.0...)
Managed to get through to someone to get a hub 3 sent out to see if that solves the issue, and it hasn't. Granted I've only had it up and running for around 2 hours or so, buy my BQM is still showing the same graph type.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/ed21f57018313d89434139e0fb1789d9ad...
The block of packet loss was switching over hubs.
Does anyone have any idea where I can go from here? I'm getting to my wits end trying to get this resolved over the phone. Genuinely the few posts on here have been FAR more helpful than anything else.
Any further details to help diagnose let me know and I'll grab them!
Thanks!
jpeg1
  • 4.79K
  • 264
  • 774
Superstar
Message 10 of 29
In addition to the points made by carl, there is a wide spread (6dB) of signal levels across the DOCSIS 3.0 channels, which suggests a possible problem between your Hub and the street box. It's something else that the engineer will need to look at.
It would be worth checking that the coax connections betwen the Hub and the wall are secure.
