on 19-04-2023 21:37
Hi. I’m new to virgin and already disappointed. Our internet is lagging and I cannot connect to our smart plugs. We had no issues with our service with sky so I’m hoping for a quick solution or I may need to return to them! Thank you
on 20-04-2023 10:18
What Hub do you have?
Try disabling the 5Ghz wifi temporarily and see if the plugs connect. If they do, then re-enable the 5Ghz.
on 20-04-2023 15:13
how would I do that?
thank you
on 20-04-2023 15:14
Hub 3 I think
on 21-04-2023 02:20
"how would I do that?"
Logon to the hub on 102.168.0.1, administrator password should be on bottom of hub, it’s not the WiFi password. Looking in the settings or advance settings.
on 21-04-2023 11:41
Thank you, I’ll give it a try
