I've had VM for up to 10 years, usually no problems. but lately I've been having horrible issues with my equipment, it seems to be restarting itself every few minutes or the connection on the line is noisy.
I'm posting my logs here to speed things up. any help is appreciated.
I'm on superhub 2aC.
Upstream US-1 US-2 US-3 US-4
Channel Type | 2.0 | 2.0 | 2.0 | 2.0 |
Channel ID | 6 | 3 | 4 | 5 |
Frequency (Hz) | 25800000 | 46200000 | 39400000 | 32600000 |
Ranging Status | Success | Success | Success | Success |
Modulation | 64QAM | 64QAM | 64QAM | 64QAM |
Symbol Rate (Sym/sec) | 5120000 | 5120000 | 5120000 | 5120000 |
Mini-Slot Size | 2 | 2 | 2 | 2 |
Power Level (dBmV) | 41.75 | 43.25 | 43.00 | 42.00 |
T1 Timeouts | 0 | 0 | 0 | 0 |
T2 Timeouts | 0 | 0 | 0 | 0 |
T3 Timeouts | 1 | 0 | 0 | 0 |
T4 Timeouts | 0 | 0 | 0 | 0 |
Downstream DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz) | 139000000 | 147000000 | 155000000 | 163000000 | 171000000 | 179000000 | 187000000 | 195000000 |
Lock Status(QAM Lock/FEC Sync/MPEG Lock) | Locked | Locked | Locked | Locked | Locked | Locked | Locked | Locked |
Channel ID | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 |
Modulation | 256QAM | 256QAM | 256QAM | 256QAM | 256QAM | 256QAM | 256QAM | 256QAM |
Symbol Rate (Msym/sec) | 6.952000 | 6.952000 | 6.952000 | 6.952000 | 6.952000 | 6.952000 | 6.952000 | 6.952000 |
Interleave Depth | I=12 J=17 | I=12 J=17 | I=12 J=17 | I=12 J=17 | I=12 J=17 | I=12 J=17 | I=12 J=17 | I=12 J=17 |
Power Level (dBmV) | 4.26 | 4.19 | 3.93 | 3.57 | 3.20 | 3.15 | 2.78 | 2.43 |
RxMER (dB) | 36.84 | 34.48 | 32.32 | 34.93 | 38.61 | 38.98 | 38.61 | 38.61 |
Pre RS Errors | 342149 | 1505996 | 7201163 | 3594883 | 683 | 1680 | 672 | 425 |
Post RS Errors | 4346 | 183339 | 2597198 | 452982 | 297 | 303 | 303 | 324
First Time | Last Time | Priority | Error Number | Description |
23/10/2019 19:15:55 GMT | 23/10/2019 19:15:55 GMT | Warning (5) | 84020200 | Lost MDD Timeout |
23/10/2019 19:15:51 GMT | 23/10/2019 19:15:51 GMT | Critical (3) | 84000500 | SYNC Timing Synchronization failure - Loss of Sync |
23/10/2019 19:15:50 GMT | 23/10/2019 19:15:50 GMT | Critical (3) | 84000500 | SYNC Timing Synchronization failure - Loss of Sync |
23/10/2019 19:15:47 GMT | 23/10/2019 19:15:47 GMT | Critical (3) | 84000500 | SYNC Timing Synchronization failure - Loss of Sync |
23/10/2019 19:15:44 GMT | 23/10/2019 19:15:44 GMT | Critical (3) | 84000500 | SYNC Timing Synchronization failure - Loss of Sync |
23/10/2019 19:15:43 GMT | 23/10/2019 19:15:43 GMT | Critical (3) | 84000500 | SYNC Timing Synchronization failure - Loss of Sync |
23/10/2019 19:15:27 GMT | 23/10/2019 19:15:27 GMT | Critical (3) | 84000500 | SYNC Timing Synchronization failure - Loss of Sync |
23/10/2019 19:15:26 GMT | 23/10/2019 19:15:26 GMT | Critical (3) | 84000500 | SYNC Timing Synchronization failure - Loss of Sync |
23/10/2019 19:15:23 GMT | 23/10/2019 19:15:23 GMT | Critical (3) | 84000500 | SYNC Timing Synchronization failure - Loss of Sync |
23/10/2019 19:15:20 GMT | 23/10/2019 19:15:20 GMT | Critical (3) | 84000500 | SYNC Timing Synchronization failure - Loss of Sync |
23/10/2019 19:15:18 GMT | 23/10/2019 19:15:18 GMT | Warning (5) | 84020200 | Lost MDD Timeout |
23/10/2019 19:15:03 GMT | 23/10/2019 19:15:03 GMT | Warning (5) | 84020200 | Lost MDD Timeout |
23/10/2019 19:15:01 GMT | 23/10/2019 19:15:01 GMT | Critical (3) | 84000500 | SYNC Timing Synchronization failure - Loss of Sync |
23/10/2019 19:14:58 GMT | 23/10/2019 19:14:58 GMT | Critical (3) | 84000500 | SYNC Timing Synchronization failure - Loss of Sync |
I've been reluctant to upgrade to SH3 because of the bad reputation with gaming.
