Steve_V
  • 17
Message 1 of 28
Intermittent Connection Issues and Orange Light
I'm having issues with my wifi connection, particularly noticeable when working from home. It's intermittently dropping out and losing connection. I've been with Virgin since October 2021 but not spent a lot of time at the property until recently, so it's possible it's always been like this.
My phone occasionally has trouble loading webpages and in settings it will sometimes say 'no internet connection'.
Also streaming of TV etc is sometimes an issue. Speed tests show decent speed (100Mbps+) but occasionally video will buffer randomly or drop to a lower (almost unwatchable) resolution.
Maybe worth mentioning that the hub (3.0) is showing a solid orange light and, as far as I recall, has always been like this, despite the set up guide saying it should be white. I've seen a few other posts where hubs have been replaced when this was the case. I have performed many reboots and done a full pinhole reset.
I called customer services earlier who tried to tell me we have too many devices connected (they also performed a remote reboot) but there's only two of us and while we do have a few smart bulbs and Amazon devices, as well as the usual laptops and TVs, I'm sure we don't have more than the average family and it should easily be able to cope. I had no issues with 29Mbps fibre with Vodafone before I switched to Virgin.
Kain_W
  • 3.7K
  • 102
  • 263
Message 2 of 28
Re: Intermittent Connection Issues and Orange Light
Hi Steve_V,
Thanks for your post and welcome to the community!
From checking our service I can't seem to find any readings that would contribute to the intermittency.
Can I ask also whether you're facing issues on a wired connection too?
Kain
Steve_V
  • 17
Message 3 of 28
It's difficult to tell, as the issue is most noticeable when working from home in the office and bedroom upstairs. It isn't a huge house and the signal does cover these rooms very well. Speed tests check out ok, with minimal speed loss. We're just being plagued by these occasional drop outs where it disconnects, sometimes during calls, sometimes during general working, so I don't think it's a bandwith issue - in any case 100MBps should be able to cope, given that we could work comfortably with less than 30Mbps with my previous provider.
The Smart TV, Fire TV and a Sonos are the only things plugged directly into the router via ethernet but it isn't possible for us both to work plugged into the router due to the location.
As I said, the light on the front of the router is permanently orange and has never been white, as I understand it should be, so this could indicate a problem with the router, given some of the other posts I've read on this forum.
Steve_V
  • 17
Message 4 of 28
Coincidentally, I've just experienced one of these issues.
I was streaming live TV in HD and it's just dropped to a much lower resolution. I ran a speed test on my phone and it's given me a speed of 0.07Mbps, when it's normally 100Mbps+ even on wifi upstairs.
Andrew-G
  • 11.14K
  • 1.73K
  • 5.32K
Message 5 of 28
Connect to the hub by clicking on this link http://192.168.0.1/  That should pull up the log in page for the hub.  But don't log in, just click on the link "Check router status"  That'll bring up a window with five tabs.  Open the Downstream tab.  Select all the text (Ctrl-A if using a keyboard), copy it (Ctrl-C), then paste it (Ctrl-V) into a reply here as TEXT not screenshots.  Post that, do the same for the Upstream and Network log.  You'll get an error message when you post the Network log, just click on "post" a second time.
If this pulls up nothing useful we'll suggest other tools to try.
Steve_V
  • 17
Message 6 of 28
13310000003.540256 qam25
22030000004.840256 qam9
32110000004.540256 qam10
42190000004.440256 qam11
52270000004.140256 qam12
6235000000440256 qam13
72430000003.940256 qam14
82510000003.540256 qam15
92590000003.540256 qam16
10267000000440256 qam17
112750000003.940256 qam18
122830000003.540256 qam19
132910000003.740256 qam20
142990000003.740256 qam21
153070000003.540256 qam22
16315000000440256 qam23
17323000000440256 qam24
183390000003.740256 qam26
19347000000440256 qam27
203550000003.740256 qam28
213630000003.740256 qam29
223710000003.940256 qam30
233790000003.540256 qam31
243870000003.240256 qam32
1Locked40.370
2Locked40.390
3Locked40.9110
4Locked40.9120
5Locked40.3150
6Locked40.3120
7Locked40.3150
8Locked40.3100
9Locked40.3120
10Locked40.9130
11Locked40.3150
12Locked40.9170
13Locked40.3100
14Locked40.9190
15Locked40.3140
16Locked40.3180
17Locked40.3210
18Locked40.3230
19Locked40.9140
20Locked40.3140
21Locked40.3160
22Locked40.9130
23Locked40.3150
24Locked40.3160
Steve_V
  • 17
Message 7 of 28
14619999640512064 qam1
22580000040512064 qam4
33260000040512064 qam3
43940003940512064 qam2
3ATDMA0010
4ATDMA0000
Steve_V
  • 17
Message 8 of 28
04/03/2022 05:05:9criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/03/2022 14:56:55noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/02/2022 20:30:15criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/02/2022 18:35:5noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/02/2022 18:35:4ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/02/2022 13:04:10criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/02/2022 06:35:4noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/02/2022 06:35:4ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/02/2022 19:21:43criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/02/2022 18:35:5noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/02/2022 18:35:5ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/02/2022 05:37:57criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/02/2022 06:35:4noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/02/2022 06:35:4ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/02/2022 01:37:55criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/02/2022 18:35:4noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/02/2022 18:35:4ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/02/2022 02:11:24criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/02/2022 00:57:3noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Andrew-G
  • 11.14K
  • 1.73K
  • 5.32K
Message 9 of 28
Bad news - all the hub status data is exactly where it should be, and that means we're looking for some other cause.  Let's see how latency and packet loss are on your connection: Setup a BQM which may show if there's anything going on with your VM connection.  Post a LINK to a LIVE, SHARED graph here and we'll see what's happening.  Usually needs to run for 24 hours before we can draw reasonable conclusions, but the live graph will continuously update so you can post the link immediately.
You referred to problems streaming TV - is that the ethernet connected TV?
In respect of the orange LED, we believe that for most cases that's the ageing of the blue diode in the RGB package that creates a multi-colour LED unit, and of itself usually means nothing.  It can sometimes be linked to other hub faults, but as a general rule it's anything in the range white, dirty white, light orange is seen as normal.  My old Hub 3 hub decayed over five years from white to what I describe as capuccino, without problems (and now I've got a shiney new Hub 5 that I can't recommend to anybody until the suddenly diabolical reliability of my connection is diagnosed and fixed).
Steve_V
  • 17
Message 10 of 28
Interesting that you say the orange light may be down to aging of the diode. The light has always been the same colour since I got the hub in October last year. Obviously I don't know how "new" the hub is though. The light is definitely what I would describe as a dark but bright orange.
The streaming issue affects both the TV connected by wifi upstairs and the wired one but I've noticed it happening a lot more on the wifi one - that may just be as it's the one I've been using most while working. I can't remember the wired one having any noticeable issues in the past few days.
I'll have a look at your other advice when I'm in the house more, in a day or so, as I'm going to be away for most today and tomorrow.
