mikey_9d
Message 1 of 10
Installation Problems Hub 3
I received my order today. Gone to plug in my router and there is a cable that i am not able to connect as I dont have the relevant connections on my wall. How do i go about getting my wifi up and running??
Plus will this cost me anything at all?
MatthewS1993
  • 69
  • 11
  • 21
Dialled in
Message 2 of 10
Re: Installation Problems Hub 3
If there isn’t a isolater on the wall you’ll have to call and ask for a manned install. Not sure of any prices tho
If I've helped in any way, please give me Kudos and mark my response as a helpful answer!
I am a serving Field Technician at Virgin however all responses on here are based on my experiences in the field alone and my own equipment at home and should be taken as such
carl_pearce
  • 1.42K
  • 91
  • 313
Knows their stuff
Message 3 of 10
@mikey_9d wrote:
Could you post an image of what you have?
mikey_9d
Message 4 of 10
This is my old connecter we received from our other provider.
carl_pearce
  • 1.42K
  • 91
  • 313
Knows their stuff
Message 5 of 10
That's a fibre connection.
VM uses a coax connection, usually via an 'NTL' or VM box on the outside and inside of your home.
mikey_9d
Message 6 of 10
I know it a fibre connection. but i wasn't told that i couldnt use it. Virgin knew i was with another provider and that i am a new customer not a existing 1. so why would i have there connectors in my house
carl_pearce
  • 1.42K
  • 91
  • 313
Knows their stuff
Message 7 of 10
VM only send out self install kits if the address has had VM previously.
I assume that the cabling was removed at some point without VM being made aware?
Regardless a VM staff member should be able to arrange an engineer visit.
MatthewS1993
  • 69
  • 11
  • 21
Dialled in
Message 8 of 10
To get a Quick start sent out means it’s been in before by a previous tenant at the house.
mikey_9d
Message 9 of 10
excellent. Thank you very much for your help. And sorry if i came across a little arsey. Just annoyed thats all. So i Apologise. Maybe VM should put that down as a question they need to ask then saves people having this issues in the future. i think i have booked an engineer out correctly so only time will tell. Will ring VM tomorrow and double check
Once Again Apologises for my rudeness and Thank You
MatthewS1993
  • 69
  • 11
  • 21
Dialled in
Message 10 of 10
No problem have a good xmas
