29-10-2021 09:17 - edited 29-10-2021 09:21
I am now on the 1Gbps connection and have the Hub4, however I have noted that the Hub4 is only 1gigabit LAN ports and the max speed of the line is 1180, so there is a small difference between the max speed of the line and the max speed the router can process.
As I only have 1 device connected to the LAN ports, it feel like that device is missing out of a small portion of the speed of the connection.
I know wifi can use the extra bandwidth but I can see that the new Hub5 has a 2.5gbps port, how can I get one of these?
on 29-10-2021 09:26
@AceModder wrote:<snip>
You can't. They are being sent out by invite only as far as I am aware.
on 29-10-2021 17:45
But do you have a PC with 2.5Gb or better NIC?
Two mistakes VM made with the hub 4 one saying 1Gb and not 900-950Mb and two making the hub with 1Gb ports...double shotgun to the foot.
