on 02-06-2021 19:17
I am having an issue with my Hub3 in modem only mode, it has been working fine in its current location but today has now stopped working and is showing a solid Red Led on the front.
I have run the online tests via my iPhone which all say the Hub3 is working correctly, but I have no connection to the internet via my LAN network. The router I have connected to the Hub3 show an external IP address but no internet access.
The information on the forums seems to suggest the unit has over heated and stopped working, but this only happened late in the day.
I have rebooted both a number of time but still no change, I have had a similar issue before when I was using a Hub3 as the router and the engineer who came out advised I had “burned the unit out due to very high use / constant high traffic”.Then then advised (after installing a new Hub3) I would be better to use it in modem only and use a 3rd party router, which has now worked fine since.
If this is indeed the same issue please can you arrange a replacement, or better to be sent out to my home as this will be the 4 or 5 unit that’s failed since having a Hub3 installed.
Answered! Go to Answer
on 09-06-2021 20:48
Well after an hour on the phone to technical support trying to get reconnected and as the previous comments have noted the old Hub 2ac will not work on a 350mb connection……
The guy I was speaking to went over and above to help and get me connected tried to get the 2ac work which after speaking with his manager they worked out it was not going to work, lucky I had not returned the faulty hub 3 which he was able to reconnect to get me some sort of connection back. He’s requested a “New Hub 3” be issued which means waiting again until I can get my full paid for service back.
Again I ask the Virgin Media team on here will I be compensated for the loss of my paid service?
on 09-06-2021 22:05
@BrianY Since when has the SH2ac been regraded for use on M350 service?
Since Virgin Media's supply chain was expanded about three months back to include dumpster-diving as a preferred sourcing route.
on 09-06-2021 22:13
@Menorthern Again I ask the Virgin Media team on here will I be compensated for the loss of my paid service?
Raise a formal complaint using the online form in My Virgin Media asking for compensation for the poor connection, the runaround from support, and anything else you think relevant. Write out fully in a Word-type programme so that you've got a record, so that you can consider and review it, and so that the MVM session doesn't time out before you press "submit". Expect the complaint to be handled with the same quality and consistency as VM's first line customer service, but it really doesn't matter what outcome you get. If VM pony up to your satisfaction, then all well and good. If not, regardless of what they say or do, you escalate to the industry arbitration scheme CISAS.
The staff here may be able to intervene before that and sort out an amicable resolution before you get to a CISAS escalation. If they can, that's quicker and easier, but not a reason to accept a sub-par settlement.
on 10-06-2021 06:25
I believe i accepted a settlement that could have been much better but i'm not a greedy person (5 years, dead landline is one of the problems lol) but its interesting you should say that Andrew, i have often wondered if Virgin send back out equipment that got returned without actually checking them.. I'll read more of this thread, but i'm guessing one faulty and one incapable hub is the main issue?
I'm fairly sure you'll be compensated if you've been unable to use the service, plus there's plenty of evidence for that! I hope you get your new Hub 3 and are all up and running soon!
Kind regards,
Lee
on 10-06-2021 11:35
on 10-06-2021 12:58
@chaoshusky i have often wondered if Virgin send back out equipment that got returned without actually checking them
Officially not. Apparently they are all checked before being sent out.
Having said that we've had a number of reports here from customers getting second hand hubs that had blatantly obvious faults like overheating indicators, non-function with a yellow LED, or loose components inside. And in this case sending out a hub that technically can't support the customer's package. Putting that together with the apparent failure of the supply chain that's brought VM to this place, it paints a picture of a chaotic organisation that simply has no concept of quality control or risk management.
My personal view is that the testing of returned hubs is indeed undertaken as a rigorous four stage process: (1) Shake returned equipment out of the returns bag, (2) wipe it with a greasy rag, (3) see if it stands upright, and (4) put it in a new box.
And there's probably an accountant working with management consultants to identify that if stages 2 and 3 were reversed, VM could save money by not wiping down the ones that are so broken they fall over.
on 10-06-2021 17:50
Good evening @Menorthern
I must apologies for the incorrect information I provided regarding the hub 2AC, whilst the hub 2AC in theory can support speeds of 350 there wasn't a software update for this.
I am glad to hear that you have managed to get a hub 3 re-sent to you.
If you are yet to raise a complaint regarding this, I would be more than happy to assist you with this.
Sorry once again,
Zak_M
on 10-06-2021 18:12
Good evening Zak,
I have not as yet received the replacement Hub 3 and im not holding my breath its going to turn up anytime soon with the way my issue has been handled so far.
Once i recieve the hub 3 and all is working as it should i will be issueing a full complaint regarding this whole debacle.
on 10-06-2021 18:27
It should take 3- 5 days for the hub to get to you from the date it was ordered.
No problem regarding the complaint, If you do need me to help you raise the complaint then please do let me know.
Kind regards,
Zak_M
10-06-2021 22:31 - edited 10-06-2021 22:32
@Andrew-G loose components?! Also, i'm trying not to die with laughter at your reply.. Hahaha...
Anyway, please keep us posted on any progress! @Menorthern 🙂
Kind regards,
Lee
Oily rag... Hahahaha..
