Hub to box connection to splitter
20201025_171424.jpghi guys just wondering if anyone has the same problem.  I'm currently having my living room overhaul (flooring included) and now have my tv on the wall. The hub and tv box are both connected to the splitter connector which also has it's own power sauce(does say onto if unplugged then all will stop working). So the connector goes to the wall, box, hub and power. The second picture is how the virgin engineer left it and I am struggling to figure out a way to neaten it all up. Can anyone suggest a way to cut down to amount of wires iv got just to connect the box to hub.
Tags (3)
  • 11.56K
  • 823
  • 1.64K
Re: Hub to box connection to splitter
If you've not got a unit to hide all the cables I would suggest a cable management box
https://www.amazon.co.uk/dp/B081Z5K7FL/ref=cm_sw_r_cp_apa_i_89BLFbT49JC92?_encoding=UTF8&psc=1
I work for Virgin Media and my posts are my own opinions
