Hub connection issue
Monetsgarden13
Hi, I have a Hub3. I’ve had trade workers in and unfortunately disconnected my cables. I have a 4-way splitter. I have got TV (& TiVo box, although green arrows symbols appear on the TiVo box) working but broadband hub box has green lights flashing on the hub3 at the bottom with wireless sign also in permanent green. I’ve tried reconnecting wires in diff positions but no luck - when I change positions I lose the tv connection. Cannot find any guide to the correct set up. Is there a specific way on the 4-way splitter to connect the cables to connect from wall to broadband via the splitter to get both TV and broadband working? Virgin engineer booked but can’t come for 3 days. Appreciate any help as to the correct set up.
1 ACCEPTED SOLUTION
Accepted Solutions
IMHO I think you have the unit upside down.
The yellow and blue cables go into the ports that are close together.  The screwed power lead goes to where the yellow cable is and the silver connector goes to where the blue cable is. ?
6 REPLIES 6
Hero
Might help to see a photo of the splitter showing the markings on the label for each port.
Thanks for the reply. The connection to the wall socket is the RED cable. I have the yellow end cable running from hub3 box to the splitter.
Can’t seem to attach a photo as only permitted to attach a 1mb photo. Will try again.
Thanks so much - resolved the issue completely. It looks like the tradesman put it back together wrong after finishing their work.
one further question if anyone can help - are home phone sockets required anymore?? Most phones are moving to digital I believe so can we remove all sockets and plaster?? Grateful for any thoughts.
Most ISP’s are moving to “Digital Voice” using VOIP. However older phone sockets can still be used in some cases for extensions. Mine are still in use for this very reason even though I have VOIP.
The choice of removing them is up to you.
