  • 17
baskcm
Hub and TiVo box
Hi in seem to be having a problem with my broadband and wifi
The hub keeps restoring itself with the telephone icon flashing red also the TiVo hub keeps flashing red as well
I have had a engineer out and he separated my.wifi one.ti normal the other set to 5g I believe
Now it worked fine after that now it's gone back to restoring.itself like.it.did before
Any advice would be helpful I've reset both the hub and the TiVo box no luck
  • 14.19K
  • 1.52K
  • 3.08K
Re: Hub and TiVo box
Two words.
Intelligent WiFi.
This update wipes out all the manual changes & resets the hub to factory settings.
You will need to split the WiFi bands again afterward.
Click to learn more about VIP
Use Kudos to say thanks
  • 17
baskcm
Oh so there's been another update oh great so does that mean I need another engineer out
  • 10.14K
  • 1.06K
  • 1.61K
No. If you call in and get a "helpful" agent, they can remotely access your Hub settings and do this for you. Or it is straightforward to do it yourself.
  • 17
baskcm
Ah right well I probably need a engineer anyhow I think it's the TiVo box causing it
Also trying.to get.it sorted over the phone last.tome was a pain in the ass
  • 1.49K
  • 80
  • 100
Hi baskcm,
Thanks for your post, sorry you're experiencing some issues with the broadband and TiVo again.
Let me know if you've been able to contact the team over the phone or if this is something you still need help with, then I can a closer look 🙂
Kind regards,
Alex_Rm
