on 17-12-2021 00:23
Hi all, recently “upgraded to the Hub 5”
Since then my connection has been pretty unstable.
I’ve been looking through my router stats and my levels and errors appear very high.
When gaming I’m getting a lot of packet loss errors and lag in general.
I’m fairly technical but not when it comes to the inner workings the internet and cabinet connection and channels and power levels.
I would really appreciate if somone could review these stats to see if I have an inherent problem.
My upstream power levels maybe too high from the research I’ve done on this forum so far.
My router power supply also make a high pitch electronic sound too, could this be related?
My hub is in Modem mode and I’m running an TP Link Archer C80 router which seems fine.
Many thanks in advance.
My speed test latency sits at about 18ms
upload is 220Mbps and download 20Mbps jitter about 4?
Downstream Bonded Channels
1 | 139000000 | 9.8 | 40 | QAM 256 | 1 |
2 | 147000000 | 9.2 | 40 | QAM 256 | 2 |
3 | 155000000 | 9 | 40 | QAM 256 | 3 |
4 | 163000000 | 8.7 | 40 | QAM 256 | 4 |
5 | 171000000 | 8.4 | 40 | QAM 256 | 5 |
6 | 179000000 | 8.4 | 40 | QAM 256 | 6 |
7 | 187000000 | 8 | 40 | QAM 256 | 7 |
8 | 195000000 | 8.1 | 40 | QAM 256 | 8 |
9 | 203000000 | 8 | 40 | QAM 256 | 9 |
10 | 211000000 | 8 | 40 | QAM 256 | 10 |
11 | 219000000 | 8.1 | 40 | QAM 256 | 11 |
12 | 227000000 | 7.9 | 40 | QAM 256 | 12 |
13 | 235000000 | 8.1 | 40 | QAM 256 | 13 |
14 | 243000000 | 7.8 | 40 | QAM 256 | 14 |
15 | 251000000 | 7.7 | 40 | QAM 256 | 15 |
16 | 259000000 | 7.6 | 40 | QAM 256 | 16 |
17 | 267000000 | 7.3 | 40 | QAM 256 | 17 |
18 | 275000000 | 7.3 | 40 | QAM 256 | 18 |
19 | 283000000 | 7.5 | 40 | QAM 256 | 19 |
20 | 291000000 | 7.6 | 40 | QAM 256 | 20 |
21 | 299000000 | 8.1 | 41 | QAM 256 | 21 |
22 | 307000000 | 7.9 | 41 | QAM 256 | 22 |
23 | 315000000 | 8.2 | 41 | QAM 256 | 23 |
24 | 323000000 | 8 | 41 | QAM 256 | 24 |
25 | 331000000 | 7.8 | 41 | QAM 256 | 25 |
26 | 339000000 | 7.8 | 40 | QAM 256 | 26 |
27 | 347000000 | 7.5 | 41 | QAM 256 | 27 |
28 | 355000000 | 7.7 | 41 | QAM 256 | 28 |
29 | 363000000 | 7.7 | 41 | QAM 256 | 29 |
30 | 371000000 | 7.8 | 41 | QAM 256 | 30 |
31 | 379000000 | 7.6 | 40 | QAM 256 | 31 |
1 | Locked | 40 | 14 | 369 |
2 | Locked | 40 | 18 | 213 |
3 | Locked | 40 | 17 | 206 |
4 | Locked | 40 | 19 | 194 |
5 | Locked | 40 | 14 | 144 |
6 | Locked | 40 | 17 | 152 |
7 | Locked | 40 | 13 | 190 |
8 | Locked | 40 | 17 | 163 |
9 | Locked | 40 | 14 | 199 |
10 | Locked | 40 | 12 | 192 |
11 | Locked | 40 | 13 | 232 |
12 | Locked | 40 | 22 | 187 |
13 | Locked | 40 | 22 | 179 |
14 | Locked | 40 | 12 | 148 |
15 | Locked | 40 | 11 | 176 |
16 | Locked | 40 | 14 | 194 |
17 | Locked | 40 | 71 | 178 |
18 | Locked | 40 | 18 | 180 |
19 | Locked | 40 | 19 | 139 |
20 | Locked | 40 | 11 | 114 |
21 | Locked | 41 | 11 | 85 |
22 | Locked | 41 | 0 | 83 |
23 | Locked | 41 | 19 | 110 |
24 | Locked | 41 | 19 | 106 |
25 | Locked | 41 | 11 | 96 |
26 | Locked | 40 | 21 | 102 |
27 | Locked | 41 | 21 | 116 |
28 | Locked | 41 | 20 | 111 |
29 | Locked | 41 | 17 | 101 |
30 | Locked | 41 | 12 | 97 |
31 | Locked | 40 | 128 | 105 |
1 | 60300000 | 42.8 | 5120 | QAM 64 | 1 |
2 | 53700000 | 43 | 5120 | QAM 64 | 2 |
3 | 46200000 | 42.8 | 5120 | QAM 64 | 3 |
4 | 39400000 | 43 | 5120 | QAM 64 | 4 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
This is my error log constantly this repeated over and over again
16-12-2021 23:38:34 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
16-12-2021 23:38:34 | warning | Dynamic Range Window violation |
16-12-2021 23:23:35 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
16-12-2021 23:23:35 | warning | Dynamic Range Window violation |
16-12-2021 23:12:56 | warning | RNG-RSP CCAP Commanded Power Exceeds Value |
on 23-12-2021 09:01
Hi Sismithin
Sorry to hear about Hub 5 issues
I am more than happy to take a look at this for you
I will need to send you a private message to pass security
If you can check the purple envelope top right of your screen that would be great
Gareth_L
