jones79
  • 6
Hub 5 problem - light going out
Good morning
I have a Hub 5, working fine until last night.
I have been using it in modem mode - with fixed white light on the Hub itself.
However, began having connection problems yesterday and thorugh to today - intermittently I am losing broadband seemingly (and phone line). I've noted what appears to happen is the lights go out completely on the front of the Hub.
A simple reboot brings it back to life, but then invariably, within an hour, it again misbehaves and no lights.
Tried a factory reset of the hub, but no joy. Still an issue.
Not helpful that the Service Status page says may be problem in my postcode (post running a test), but is vague and lacking detail.
Any insight, in particularly on why the lights may be going out compeltely on the Hub, yet works fine after a reboot?
Will call Virgin when i get a chance today, but thought I'd post here to see if anybody has experienced same?
Thanks!
Rhys
Tags (2)
  • 13.9K
  • 1.08K
  • 2.82K
Re: Hub 5 problem - light going out
If you are in modem mode on a Hub5 then the LED should be green not white. Also check with Area faults on 0800 561 0061 If you have a VM landline 150 this goes down to post code level. You could also try the web page status, but this is not recommended as it only covers issues that affect a very large number of customers.
jones79
  • 6
Apoligies - i have it in router more only, hence the white light - my error.
The telephone number message does suggest local issues to be fair, I will still call them however.
But am puzzled as to why no lights show when down? Given this isn't noted anywhere here for instance:
https://www.virginmedia.com/help/broadband/virgin-media-wifi-not-working
Matthew_ML
  • 3.61K
  • 132
  • 242
Hey jones79, thank you for reaching out and a warm welcome to the community I am so sorry to hear you are having connection issues.
I have taken a look at our side and I can see there is an SNR outage lasting until 4th Feb 2023, this will be affecting the overall performance for the internet.
You can keep an eye for update here  or our outage outline 0800 561 0061. Thanks
Matt - Forum Team
New around here?
