on 01-10-2022 12:43
Trying to access settings on new hub 5. Tried 60 sec pinhole reset. Still not working.
on 01-10-2022 13:32
Are you using the password on the bottom of the hub not the one on the pull out card at the top?
on 01-10-2022 17:18
Been through a bunch of forums and I'm pretty tech savvy. Definitely using the SETTINGS password, and all correct case etc. I'm NOT using the wifi password. I've done a pin hole full factory reset and it's still the same.
Is it just the wrong sticker or something??
on 03-10-2022 18:40
Hello JamieAAAA,
Thanks for your post. Sorry you are unable to access the Hub5 settings.
Have you been able to access them before?
The sticker will be correct if you can access the WIFI network okay using the password.
Gareth_L
on 09-10-2022 21:16
The Wi-Fi password works fine. So it’s obviously the right sticker, however, like I’ve already stated the settings password does not work even after four pinhole resets, et cetera.
on 09-10-2022 23:28
When I installed my Hub5 I could not continue until I had changed the setting password from the default. Perhaps you changed yours. A pin hole reset will get it back to the ‘sticker’ one.
on 05-07-2023 01:38
I tired doing the pin hole reset aswell but it doesn't work still keeps on saying wrong password this is driving me insane can you please help
on 05-07-2023 10:11
@Ray26 wrote:I tired doing the pin hole reset aswell but it doesn't work still keeps on saying wrong password this is driving me insane can you please help
Was the reset done properly? How was it performed and for how long? Press for a full 60 seconds then allow to boot up fully for say 10 minutes.
Try using a different browser, clearing the cache and so on.
If it still doesn't work you may need a new hub?
on 05-07-2023 10:51
Hi JamieAAAA
Thank you for your post and welcome back to our community.
I am sorry to hear you are having some issues with the settings on your new hub.
Have the suggestions from the community here resolved this?
Please pop back to us when you can.
Vikki - Forum Team
