Hub 4 overheating and making a loud whirring noise
Fergujj
Hi, I had a Hub 4 installed about 6 weeks ago. However, it's now making a loud whirring noise and is warm to touch. It's positioned away from direct sunlight in a fairly well ventilated / dust free room. Should I be concerned?
1 ACCEPTED SOLUTION
Accepted Solutions
Sounds like it maybe needs the dust hoovered out? The Hub 4 takes air in from the bottom I believe so it can also suck up dust over time.
4 REPLIES 4
John_GS
Hi Fergujj
I am sorry to hear that the hub is making that noise and also hot to touch. The advice from adduxi regarding the hub 4 is correct (thanks as always) but I can see you've spoke to the team since the post, got an engineer out who's attended and sorted this 🙂
Keep us posted if you need further assistance.
Kind regards,
John_GS
Hi John,
Yes, we had a visit this morning from Marcel who has replaced the noisy Hub 4 with a new one.
Silence is golden! 👍
Glad to hear that the issue has been resolved @Fergujj.
Please continue to monitor the hub and let us know if you need any further help.
Akua_A
