on 31-07-2021 13:19
Hi All,
I have just setup my hub 4 and discovered it doesn’t work with the virginmedia connect app. Are there any plans to make the app work with it as I can check nothing at all?
Also does this now mean that we have also lost the hotspots? and now can’t connect to internet if away from home or can we still connect outside?
Thanks for reading I must admit if the app won’t work then I am very disappointed with the new hub already.
Emmalou
Answered! Go to Answer
on 31-07-2021 14:59
on 31-07-2021 14:59
on 31-07-2021 15:40
Thank you for your reply John this is helpful I appreciate your answer.
I’ll keep an eye on it and see what happens.
Emmalou
