Jayroper1979
Hub 3 won’t connect
Hi got a hub 3 yesterday but won’t connect
to connect app says can’t find hub also
says weak security on wi fi setting
DJ_Shadow1966
  • 7.1K
  • 1.36K
  • 2.01K
Re: Hub 3 won’t connect
Hello
What are the lights on the  front of the hub doing ?
Dud you activate the hub by calling 0800 953 9500
The device using the connect app has too be connected to the hubs wireless, but it could also be caused by the first probem.
The week security is an issue with iPhone see https://community.virginmedia.com/t5/Networking-and-WiFi/iOS-14-Weak-Security/td-p/4410050 for the fix.
Regards Mike
Jayroper1979
Just a white light on bottom
did not no u have to call them
as had a leaflet to set it up
Jayroper1979
Thanks all done phone them
