Lukeb123
Hub 3 settings password won’t reset.
Tried to reset the router as I can’t get access to the settings but it still won’t accept the code on the bottom of the router.
tried the hard reset ( 60seconds pressing reset and power off for 10 mins) x3 but now joy. Anyone know of any solutions?
jpeg1
  • 5.45K
  • 284
  • 898
Superstar
Re: Hub 3 settings password won’t reset.
Are you sure you are using the correct password?
Lukeb123
Yes I’m using the settings code on the bottom of the router.
jpeg1
  • 5.45K
  • 284
  • 898
Superstar
I would try the factory default settings again, and if that doesn't work then ask for a new Hub.
This time, after pressing the button don't turn the Hub off.
SonarUK
  • 576
  • 25
  • 72
Rising star
While the Hub is switched on put a pin into the reset hole. wait for around 20-30 seconds. take the pin out. do not turn the hub off. the hub should restart its self.
When the hub restarts remember to wait at least 10 minutes before trying to log back in.
https://twitter.com/SeriousFamily
M500 | Hub 3 Modem Mode | Asus RT-AX86U (Stock-Firmware)
  • 9.34K
  • 734
  • 1.72K
As above, the VM instructions are wrong, DO NOT TURN OFF THE HUB after doing a 60 second pin hole reset. /
