on 10-10-2021 09:37
Yesterday I received a Hub 3 on an old equipment swap basis. This morning I plugged it in and nothing, no lights no sounds, just nothing, it's like it's dead out of the box. The switch is definitely in the on postion and was cycled for good measure.
I tried plugging the Hub into a different socket and l read that it can take up to 10 minutes for the Hub to 'wake up'. I left it for 15 minutes and unit still appears dead.
I checked the output from the power adapter and the voltage is good at 12.16Volts.
Maybe there's something I'm missing. Is it likely I've received a completely dead unit out of the box?
on 10-10-2021 09:59
Very likely. VM re-use equipment returned when customers leave, and (judging by reports here) there's little or no quality control on them,
A detailed process map: Wipe the baked bean stains off >Call it "refurbished", >Send it out again. And even step 1 is optional.
Your quickest fix is to phone this in.
on 10-10-2021 10:25
Fair enough and yes, I called Virgin and they are sending out an engineer with a replacement unit.
on 12-10-2021 10:45
Hello @Talisker1924,
Welcome back! Thank you for posting.
Thank you for the update on what is happening, I am sorry for the issues with your Hub-3.
Please let us know how everything goes with the engineer visit.
Many thanks,
on 12-10-2021 11:02
It was a dead box and has now been replaced.
on 14-10-2021 11:12
Hi Talisker1924
Thank you for getting back to us here on the Community.
I am please to hear the equipment has been replaced. How have things been since then? Have you seen any improvements?
on 18-10-2021 08:19
With the old 2ac router, I was having an issue where the unit would dump the connection to the internet 2 or 3 times a week only being resolved with a full reboot each time.
The hub 3 seems to have solved this issue.
on 20-10-2021 08:24
Great to hear Talisker1924,
Thanks for letting us know 🙂
Alex_Rm
