on 02-02-2022 14:31
I'm having intermittent connectivity on my hub 3 and this has been happening randomly over the past 4 days. I've had a VM engineer out this morning who checked all the cabling in the house and in the street and replaced the existing hub 3 with a new one however this hasn't fixed anything. I've also phoned twice today after experiencing the issue and phone support cant see an issue with the hub or the line but there definitely is a problem.
My setup is currently all hard wired (no wifi) and the hub3 is in modem mode but I can see the issue occurs on the hub3 and not the router as it appears to reboot when the issue happens. I setup a broadband quality monitor this morning after seeing the issue here https://www.thinkbroadband.com/broadband/monitoring/quality/share/dec972b457d5ca9237d4a335b152c9b903....
While running multiple ping tests, what ive noticed is the hub becomes inaccessible before the internet does and then after roughly 30 seconds the hub comes back to life but the internet will not return for ~3 minutes.
on 02-02-2022 14:32
Below are the pages from the router:
1 331000000 2 40 256 qam 25
2 219000000 2 40 256 qam 11
3 227000000 1.5 40 256 qam 12
4 235000000 1.7 40 256 qam 13
5 243000000 1 40 256 qam 14
6 251000000 1.2 40 256 qam 15
7 259000000 1.5 40 256 qam 16
8 267000000 2 40 256 qam 17
9 275000000 2.9 40 256 qam 18
10 283000000 2 40 256 qam 19
11 291000000 2 40 256 qam 20
12 299000000 1.4 40 256 qam 21
13 307000000 1.5 40 256 qam 22
14 315000000 1.5 40 256 qam 23
15 323000000 1.5 40 256 qam 24
16 339000000 1.7 40 256 qam 26
17 347000000 2 40 256 qam 27
18 355000000 1.5 40 256 qam 28
19 363000000 1.5 40 256 qam 29
20 371000000 1.5 40 256 qam 30
21 379000000 1.4 40 256 qam 31
22 387000000 1.5 40 256 qam 32
23 395000000 1 40 256 qam 33
24 403000000 1 40 256 qam 34
1 Locked 40.9 4 0
2 Locked 40.9 6 0
3 Locked 40.3 4 0
4 Locked 40.9 6 0
5 Locked 40.9 0 0
6 Locked 40.9 6 0
7 Locked 40.9 0 0
8 Locked 40.3 0 0
9 Locked 40.9 0 0
10 Locked 40.9 0 0
11 Locked 40.3 0 0
12 Locked 40.3 6 0
13 Locked 40.3 5 0
14 Locked 40.9 6 0
15 Locked 40.3 0 0
16 Locked 40.3 0 0
17 Locked 40.9 4 0
18 Locked 40.3 0 0
19 Locked 40.3 5 0
20 Locked 40.9 0 0
21 Locked 40.9 5 0
22 Locked 40.9 5 0
23 Locked 40.9 0 0
24 Locked 40.9 0 0
1 53700002 43.3 5120 64 qam 2
2 39399983 43.3 5120 64 qam 4
3 46199996 43.3 5120 64 qam 3
4 60300009 43.3 5120 64 qam 1
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0
0
02/02/2022 11:01:17 notice LAN login Success;CM-MAC=*;CMTS-MAC=*M-QOS=1.1;CM-VER=3.0;
02/02/2022 11:01:7 Warning! LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=*;CMTS-MAC=*;CM-QOS=1.1;CM-VER=3.0;
02/02/2022 10:26:12 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=*;CMTS-MAC=*;CM-QOS=1.1;CM-VER=3.0;
02/02/2022 10:26:12 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=*;CMTS-MAC=*;CM-QOS=1.1;CM-VER=3.0;
02/02/2022 10:07:22 notice LAN login Success;CM-MAC=*;CMTS-MAC=*;CM-QOS=1.1;CM-VER=3.0;
02/02/2022 10:04:34 Warning! LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=*;CMTS-MAC=*;CM-QOS=1.1;CM-VER=3.0;
02/02/2022 09:10:20 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=*;CMTS-MAC=*;CM-QOS=1.1;CM-VER=3.0;
02/02/2022 09:10:20 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=*;CMTS-MAC=*;CM-QOS=1.1;CM-VER=3.0;
02/02/2022 08:43:7 notice LAN login Success;CM-MAC=*;CMTS-MAC=*;CM-QOS=1.1;CM-VER=3.0;
02/02/2022 08:36:9 notice SW download Successful - Via Config file
02/02/2022 08:34:14 notice SW Download INIT - Via Config file
01/01/1970 00:01:38 critical No Ranging Response received - T3 time-out;CM-MAC=*;CMTS-MAC=*;CM-QOS=1.1;CM-VER=3.0;
on 02-02-2022 15:15
The most recent occurrence of this actually left something in the network log unlike the past several occurences:
02/02/2022 14:10:19 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
on 02-02-2022 15:39
Try a full factory reset on the Hub as below. Once done you will need to put the Hub back into modem mode before you re-connect your Router.
Remove any ethernet cables from the Hub and hold the pinhole reset switch for 60 seconds. Do NOT reboot the Hub, just let it do it's thing. Note you will need the passwords from the bottom of the Hub afterwards, so make sure they are legible.
on 02-02-2022 15:59
I have just done exactly what you recommenced so hopefully I see some better results but time will tell.
