on 15-10-2022 11:31
Here are my stats for the Hub 3.
1 | 203000000 | 7.8 | 40 | 256 qam | 9 |
2 | 139000000 | 8.3 | 40 | 256 qam | 1 |
3 | 147000000 | 8.4 | 40 | 256 qam | 2 |
4 | 155000000 | 8.5 | 40 | 256 qam | 3 |
5 | 163000000 | 8.5 | 40 | 256 qam | 4 |
6 | 171000000 | 8.5 | 40 | 256 qam | 5 |
7 | 179000000 | 8.3 | 40 | 256 qam | 6 |
8 | 187000000 | 8.1 | 40 | 256 qam | 7 |
9 | 195000000 | 8 | 40 | 256 qam | 8 |
10 | 211000000 | 7.5 | 40 | 256 qam | 10 |
11 | 219000000 | 7 | 40 | 256 qam | 11 |
12 | 227000000 | 6.8 | 38 | 256 qam | 12 |
13 | 235000000 | 6.4 | 40 | 256 qam | 13 |
14 | 243000000 | 6.3 | 40 | 256 qam | 14 |
15 | 251000000 | 6.5 | 40 | 256 qam | 15 |
16 | 259000000 | 6.8 | 40 | 256 qam | 16 |
17 | 267000000 | 7.3 | 40 | 256 qam | 17 |
18 | 275000000 | 7.4 | 40 | 256 qam | 18 |
19 | 283000000 | 7.3 | 40 | 256 qam | 19 |
20 | 291000000 | 7.3 | 40 | 256 qam | 20 |
21 | 299000000 | 7.4 | 40 | 256 qam | 21 |
22 | 307000000 | 7.1 | 40 | 256 qam | 22 |
23 | 315000000 | 7 | 40 | 256 qam | 23 |
24 | 323000000 | 6.5 | 40 | 256 qam | 24 |
1 | Locked | 40.3 | 760 | 3165 |
2 | Locked | 40.3 | 1112 | 4930 |
3 | Locked | 40.3 | 711 | 5331 |
4 | Locked | 40.9 | 2912 | 5338 |
5 | Locked | 40.3 | 609 | 4504 |
6 | Locked | 40.3 | 747 | 4535 |
7 | Locked | 40.3 | 989 | 4184 |
8 | Locked | 40.3 | 862 | 3884 |
9 | Locked | 40.9 | 938 | 4965 |
10 | Locked | 40.3 | 749 | 3003 |
11 | Locked | 40.9 | 460 | 3017 |
12 | Locked | 38.9 | 665 | 3254 |
13 | Locked | 40.3 | 537 | 3388 |
14 | Locked | 40.3 | 663 | 3265 |
15 | Locked | 40.3 | 590 | 3468 |
16 | Locked | 40.3 | 949 | 3403 |
17 | Locked | 40.3 | 556 | 3417 |
18 | Locked | 40.3 | 742 | 3325 |
19 | Locked | 40.3 | 1054 | 3836 |
20 | Locked | 40.3 | 1056 | 4336 |
21 | Locked | 40.3 | 866 | 11036 |
22 | Locked | 40.3 | 826 | 10825 |
23 | Locked | 40.3 | 969 | 11004 |
24 | Locked | 40.3 | 983 | 11384 |
1 | 23600000 | 48.5 | 5120 | 64 qam | 5 |
2 | 49600000 | 48.5 | 5120 | 64 qam | 1 |
3 | 30100000 | 48.5 | 5120 | 64 qam | 4 |
4 | 36600000 | 48.3 | 5120 | 64 qam | 3 |
5 | 43100000 | 48.3 | 5120 | 64 qam | 2 |
1 | ATDMA | 0 | 0 | 19 | 0 |
2 | ATDMA | 0 | 0 | 3 | 0 |
3 | ATDMA | 0 | 0 | 4 | 0 |
4 | ATDMA | 0 | 0 | 5 | 0 |
5 | ATDMA | 0 | 0 | 9 | 0 |
on 15-10-2022 12:04
Too many T3 an Post RS errors, but the figures are accumulative since the hub was last power cycled. So please turn off your hub for a short period, this will reset the counters, then post a new full set of stats after about two hours. This will indicate the current line status.
on 18-10-2022 00:46
These Logs are a few days after the power down of the hub.
1 | 203000000 | 7.6 | 40 | 256 qam | 9 |
4 | 155000000 | 8.4 | 40 | 256 qam | 3 |
7 | 179000000 | 8 | 40 | 256 qam | 6 |
8 | 187000000 | 8 | 40 | 256 qam | 7 |
12 | 227000000 | 6.6 | 38 | 256 qam | 12 |
13 | 235000000 | 6.3 | 38 | 256 qam | 13 |
16 | 259000000 | 7 | 40 | 256 qam | 16 |
17 | 267000000 | 7.4 | 40 | 256 qam | 17 |
19 | 283000000 | 7.4 | 40 | 256 qam | 19 |
22 | 307000000 | 7 | 40 | 256 qam | 22 |
1 | Locked | 40.3 | 25 | 0 |
2 | Locked | 40.3 | 25 | 0 |
3 | Locked | 40.3 | 27 | 0 |
4 | Locked | 40.3 | 41 | 0 |
5 | Locked | 40.3 | 35 | 0 |
6 | Locked | 40.3 | 31 | 0 |
7 | Locked | 40.3 | 27 | 0 |
8 | Locked | 40.3 | 31 | 0 |
9 | Locked | 40.9 | 36 | 0 |
10 | Locked | 40.3 | 35 | 0 |
11 | Locked | 40.3 | 33 | 0 |
12 | Locked | 38.9 | 30 | 0 |
13 | Locked | 38.9 | 26 | 0 |
14 | Locked | 40.3 | 22 | 0 |
15 | Locked | 40.3 | 16 | 0 |
16 | Locked | 40.3 | 45 | 0 |
17 | Locked | 40.3 | 21 | 0 |
18 | Locked | 40.3 | 31 | 0 |
19 | Locked | 40.3 | 28 | 0 |
20 | Locked | 40.3 | 40 | 0 |
21 | Locked | 40.3 | 43 | 0 |
22 | Locked | 40.3 | 40 | 0 |
23 | Locked | 40.3 | 26 | 0 |
24 | Locked | 40.3 | 33 | 0 |
3 | 30100000 | 48.3 | 5120 | 64 qam | 4 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
5 | ATDMA | 0 | 0 | 0 | 0 |
on 20-10-2022 08:35
Good Morning @MacmillaN, thanks for your post and welcome back to our Forums!
I've looked into your local area, and can confirm that an local area outage is flagged and is estimated to be resolved on 21/10/22 at 14:10.
Do please come back to us after this time frame has passed and we'll take a closer look if this issue is still ongoing.
Sorry for any inconvenience this may cause you.
Kindest regards,
David_Bn
on 24-10-2022 16:49
on 26-10-2022 18:26
Hi MacmillaN,
Thank for reaching back out, I have had a look our end and can see the area issue has cleared however I can also see you haven't done a reboot recently since the issue occurred, please unplug the Router from the power and leave for 2 to 3 minutes then plug back in.
Paul.
on 13-11-2022 03:45
1 | 203000000 | 7.5 | 40 | 256 qam | 9 |
2 | 139000000 | 8.1 | 40 | 256 qam | 1 |
3 | 147000000 | 8.3 | 40 | 256 qam | 2 |
5 | 163000000 | 8.3 | 40 | 256 qam | 4 |
6 | 171000000 | 8.4 | 40 | 256 qam | 5 |
10 | 211000000 | 7.4 | 40 | 256 qam | 10 |
11 | 219000000 | 6.9 | 40 | 256 qam | 11 |
12 | 227000000 | 6.5 | 38 | 256 qam | 12 |
13 | 235000000 | 6.1 | 38 | 256 qam | 13 |
14 | 243000000 | 6 | 40 | 256 qam | 14 |
18 | 275000000 | 7.1 | 40 | 256 qam | 18 |
19 | 283000000 | 7 | 40 | 256 qam | 19 |
20 | 291000000 | 7 | 40 | 256 qam | 20 |
21 | 299000000 | 7 | 40 | 256 qam | 21 |
23 | 315000000 | 6.9 | 40 | 256 qam | 23 |
24 | 323000000 | 6.4 | 40 | 256 qam | 24 |
1 | Locked | 40.3 | 8 | 0 |
2 | Locked | 40.3 | 14 | 0 |
3 | Locked | 40.3 | 15 | 0 |
4 | Locked | 40.3 | 26 | 0 |
5 | Locked | 40.3 | 31 | 0 |
6 | Locked | 40.3 | 17 | 0 |
7 | Locked | 40.3 | 24 | 0 |
8 | Locked | 40.3 | 25 | 0 |
9 | Locked | 40.3 | 23 | 0 |
10 | Locked | 40.3 | 13 | 0 |
11 | Locked | 40.3 | 17 | 0 |
12 | Locked | 38.9 | 16 | 0 |
13 | Locked | 38.9 | 9 | 0 |
14 | Locked | 40.3 | 14 | 0 |
15 | Locked | 40.3 | 10 | 0 |
16 | Locked | 40.3 | 24 | 0 |
17 | Locked | 40.3 | 9 | 0 |
18 | Locked | 40.3 | 13 | 0 |
19 | Locked | 40.3 | 11 | 0 |
20 | Locked | 40.3 | 14 | 0 |
21 | Locked | 40.3 | 22 | 0 |
22 | Locked | 40.3 | 22 | 0 |
23 | Locked | 40.3 | 24 | 0 |
24 | Locked | 40.3 | 25 | 0 |
1 | 23600039 | 48.8 | 5120 | 64 qam | 5 |
2 | 49599990 | 49 | 5120 | 64 qam | 1 |
3 | 30100000 | 48.8 | 5120 | 64 qam | 4 |
4 | 36600000 | 48.8 | 5120 | 64 qam | 3 |
5 | 43100000 | 48.8 | 5120 | 64 qam | 2 |
1 | ATDMA | 0 | 0 | 1 | 0 |
