on 27-01-2022 09:16
Hello
We have been suffering with latency and packet loss at certain times of day over the last few days that can be seen on our broadband monitor graph (snapshot showing yesterday). It happens for a few minutes and then everything is ok again, very noticeable when on Teams calls.
Would someone be able to check over our hub 3.0 downstream/upstream stats please?
Thanks in advanced!
Item Status Comments
Acquired Downstream Channel (Hz) | 370750000 | Locked |
Ranged Upstream Channel (Hz) | 32600000 | Locked |
Provisioning State | Online |
1 | 370750000 | 0 | 40 | 256 qam | 30 |
2 | 202750000 | -0.4 | 38 | 256 qam | 9 |
3 | 210750000 | -0.4 | 38 | 256 qam | 10 |
4 | 218750000 | -0.5 | 38 | 256 qam | 11 |
5 | 226750000 | -1.5 | 38 | 256 qam | 12 |
6 | 234750000 | -2.2 | 38 | 256 qam | 13 |
7 | 242750000 | -2.7 | 38 | 256 qam | 14 |
8 | 250750000 | -2.7 | 38 | 256 qam | 15 |
9 | 258750000 | -2.5 | 38 | 256 qam | 16 |
10 | 266750000 | -2 | 38 | 256 qam | 17 |
11 | 274750000 | -1.4 | 38 | 256 qam | 18 |
12 | 282750000 | -0.5 | 38 | 256 qam | 19 |
13 | 290750000 | 0.5 | 38 | 256 qam | 20 |
14 | 298750000 | 1.2 | 40 | 256 qam | 21 |
15 | 306750000 | 0.5 | 38 | 256 qam | 22 |
16 | 314750000 | 0.4 | 38 | 256 qam | 23 |
17 | 322750000 | 1 | 40 | 256 qam | 24 |
18 | 330750000 | 0.7 | 38 | 256 qam | 25 |
19 | 338750000 | 0.2 | 40 | 256 qam | 26 |
20 | 346750000 | 0.7 | 38 | 256 qam | 27 |
21 | 354750000 | 0.5 | 40 | 256 qam | 28 |
22 | 362750000 | 0 | 40 | 256 qam | 29 |
23 | 378750000 | 0 | 38 | 256 qam | 31 |
24 | 386750000 | -1 | 38 | 256 qam | 32 |
1 | Locked | 40.3 | 701 | 1806 |
2 | Locked | 38.6 | 750 | 2347 |
3 | Locked | 38.9 | 869 | 5633 |
4 | Locked | 38.9 | 709 | 2805 |
5 | Locked | 38.6 | 846 | 2592 |
6 | Locked | 38.9 | 1097 | 2856 |
7 | Locked | 38.9 | 1327 | 6298 |
8 | Locked | 38.9 | 1278 | 3674 |
9 | Locked | 38.9 | 1364 | 3165 |
10 | Locked | 38.6 | 1138 | 2811 |
11 | Locked | 38.9 | 939 | 3061 |
12 | Locked | 38.9 | 863 | 5572 |
13 | Locked | 38.9 | 778 | 3457 |
14 | Locked | 40.3 | 728 | 6286 |
15 | Locked | 38.9 | 885 | 4842 |
16 | Locked | 38.9 | 820 | 5049 |
17 | Locked | 40.9 | 699 | 5059 |
18 | Locked | 38.9 | 982 | 3906 |
19 | Locked | 40.3 | 920 | 5115 |
20 | Locked | 38.9 | 753 | 4018 |
21 | Locked | 40.3 | 876 | 7867 |
22 | Locked | 40.3 | 828 | 4884 |
23 | Locked | 38.6 | 714 | 3755 |
24 | Locked | 38.9 | 821 | 3454 |
1 | 32600000 | 45.3 | 5120 | 64 qam | 3 |
2 | 25800000 | 45.3 | 5120 | 64 qam | 4 |
3 | 39400000 | 46.3 | 5120 | 64 qam | 2 |
4 | 46200000 | 45.8 | 5120 | 64 qam | 1 |
1 | ATDMA | 0 | 0 | 30 | 0 |
2 | ATDMA | 0 | 0 | 36 | 0 |
3 | ATDMA | 0 | 0 | 24 | 0 |
4 | ATDMA | 0 | 0 | 35 | 0 |
on 27-01-2022 10:32
Far too many PostRS errors on the line. Ideally these should be zero. You will need a VM technician to find and fix the issue, usually noise ingress.
on 01-02-2022 15:52
Hey @neilz,
Welcome back to the community and thanks for taking the time to post here on the forums.
I'm sorry for the late reply to your post and for the issues that you were having at the time of posting, I have looked into our system and cannot see anything that would be causing issues at the moment. Are the issues still ongoing for you at the moment?
Regards,
Steven_L
on 01-02-2022 16:17
on 01-02-2022 16:21
Sorry Steven, just checked the modem and there an awful lot of post rs errors again?
Looking at BQM there was some packet loss again today just after 12pm and some yesterday 5pm, 8pm and near 10pm that may be linked?
1 | Locked | 37.6 | 546 | 7014 |
2 | Locked | 37.3 | 509 | 6904 |
3 | Locked | 37.3 | 525 | 6906 |
4 | Locked | 37.6 | 584 | 7388 |
5 | Locked | 37.6 | 591 | 6954 |
6 | Locked | 38.6 | 603 | 7533 |
7 | Locked | 38.6 | 627 | 7192 |
8 | Locked | 38.6 | 641 | 7283 |
9 | Locked | 38.6 | 564 | 7478 |
10 | Locked | 38.6 | 622 | 7534 |
11 | Locked | 38.9 | 439 | 8315 |
12 | Locked | 38.6 | 330 | 8394 |
13 | Locked | 38.6 | 454 | 8103 |
14 | Locked | 38.6 | 484 | 8222 |
15 | Locked | 38.6 | 475 | 8176 |
16 | Locked | 38.9 | 448 | 8300 |
17 | Locked | 38.6 | 400 | 8380 |
18 | Locked | 38.6 | 430 | 8532 |
19 | Locked | 38.9 | 394 | 386 |
20 | Locked | 38.9 | 427 | 432 |
21 | Locked | 38.9 | 585 | 1045 |
22 | Locked | 38.9 | 651 | 1054 |
23 | Locked | 40.3 | 616 | 1136 |
24 | Locked | 40.3 | 643 | 1158 |
on 01-02-2022 16:27
All the error counts are accumulative since the hub was last power cycled. So to reset all the counts and make it vary obvious to VM that there is a circuit problem could you please power cycle your hub and then post a new set of stats after an hour or so. This will show the current figures. I would also be worried by the T3 errors on the upstream which were high.
01-02-2022 16:29 - edited 01-02-2022 16:30
Hi Tudor
Current upstream timeouts are below. The hub was last power cycled on Friday 28th January, but will reboot it shortly and post again.
Thank you
1 | ATDMA | 0 | 0 | 6 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 2 | 0 |
4 | ATDMA | 0 | 0 | 1 | 0 |
on 02-02-2022 08:09
Morning
I rebooted the hub yesterday evening around 4.45pm and the stats are as below so far. I think whatever is causing the random bursts of errors and packet loss is random. I will monitor today and see if they jump throughout the working day suddenly like I suspect.
1 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
1 | Locked | 38.6 | 7 | 0 |
2 | Locked | 37.6 | 7 | 0 |
3 | Locked | 37.6 | 5 | 0 |
4 | Locked | 37.3 | 7 | 0 |
5 | Locked | 38.6 | 8 | 0 |
6 | Locked | 38.6 | 5 | 0 |
7 | Locked | 38.9 | 7 | 0 |
8 | Locked | 38.6 | 23 | 0 |
9 | Locked | 38.6 | 18 | 0 |
10 | Locked | 38.6 | 7 | 0 |
11 | Locked | 38.9 | 7 | 0 |
12 | Locked | 38.9 | 6 | 0 |
13 | Locked | 38.6 | 8 | 0 |
14 | Locked | 38.6 | 14 | 0 |
15 | Locked | 38.9 | 8 | 0 |
16 | Locked | 38.9 | 2 | 0 |
17 | Locked | 38.9 | 9 | 0 |
18 | Locked | 38.6 | 13 | 0 |
19 | Locked | 38.9 | 7 | 0 |
20 | Locked | 38.9 | 8 | 0 |
21 | Locked | 40.3 | 6 | 0 |
22 | Locked | 38.9 | 17 | 0 |
23 | Locked | 40.3 | 18 | 0 |
24 | Locked | 40.3 | 18 | 0 |
on 06-02-2022 11:35
Hi @neilz,
Thank you for expanding. I am really sorry to hear that this issue is unfortunately ongoing for you.
I'm going to send you a private message in a few moments so that we can investigate what's going on a little further. Please response to this at your earliest convenience.
on 09-02-2022 13:29
Hi @neilz,
Thank you for getting back to us via private message so that we could take a closer look over things for you.
As discussed, a known area impacting fault has been detected which would explain the issues you're experiencing, and the current estimated fix time is approximately 6:00pm today. If the issues persist beyond this, please check on our Service Status page to see if an updated time has been put in place.
If nothing is being reported there but your service issues remain, let us know and we can go from there.
