Yinnn
Settling in
Hub 3.0 flashig green base light
The base light on my hub has been flashing green since morning. I have tried switching off and on the hub but it’s not working. When i switch it back on the sequence is as follows (1) base is steady white; then (2) all the 'icons' light up red then green and then they go off again; (3) the white solid base starts to flash white and then (4) the base starts to flash green and the wifi symbol lights up as a permanent green.
How can i fix this asap??
  • 6.25K
  • 482
  • 1.03K
Hero
Re: Hub 3.0 flashig green base light
If you have an internet connection, ignore it, if not phone customer services and report the fault.
  • 5.3K
  • 105
Moderator (Retired) Ty_S
Moderator (Retired)
Hi Yinnn
Everything looks great when checking your connection over. Are you having any trouble with the connection?
Speak soon
