  • 9
RobboC
Message 1 of 12
Hub 3.0 Keeps Losing Passwords and Settings
Hi all,
In the last month or so my 3.0 Hub has started to lose all its settings after a powercut.  I have to set it up as a new router after every occasion.  It will also occasionally randomly reset the settings without there being a power cut.
I'm making sure I save the settings but it still happens?
Many thanks
novamob
Message 2 of 12
Re: Hub 3.0 Keeps Losing Passwords and Settings
Hiya
Yes, this has been happening for me too, just over the last few months. It's not all the time - every few weeks or so -  but it's a proper pain when it does.
No powercuts, it just decides to reboot itself and go back to factory settings. Happened just this morning.
Any angle on this would be great.
  • 9
RobboC
Message 3 of 12
Mine happened just last night.  It is a pain as I have a number of different settings I have to keep entering in.  I'm not sure why it should suddenly loose these.  I wonder if there is an internal back up battery?
  • 4.62K
  • 547
  • 733
Superstar
Message 4 of 12
If you havent tried this already, next time it happens, do a pinhole reset to factory settings.  Push the pin in to its stop point and hold for a "timed" 40 seconds do NOT restart the router after that.  Then put in all your changes - see if that helps.
  • 9
RobboC
Message 5 of 12
No this didn't help sadly, did it again.
  • 9
RobboC
Message 6 of 12
Can any techies from Virgin on here help?
  • 11.37K
  • 405
  • 1K
Message 7 of 12
Put the hub in modem mode with a PC and see if it resets back to router mode. Then use it in modem mode and get your own router with 1Gb ports.
  • 9
RobboC
Message 8 of 12
I know I could do that, but I don't really want to have to buy another router.  The equipment is clearly faulty.
dcolhoun
Message 9 of 12
This is happening to me too. Virgin help were no help, telling me they had optimised some settings. This is a hardware fault and I would think replacement is the solution.
Would support like to comment
  • 14.59K
  • 432
  • 1.22K
Moderator
Moderator
Message 10 of 12
Hi dcolhoun/RobboC
Sorry for the Hub problems, could you please perform a pin hole reset and let us know if this helps, if problems persist we'll get in touch to look at arranging a replacement.
Cheers
Ralph_R
Forum Moderator
