on 16-09-2022 09:30
Having complained to Virginmedia recently about speed engineer atteneded and swapped my Hub 2AC to a Hub3...
Now i thought the connections to a Hub3 were automatic as if connectimg to a 2.4 or 5 channel.., in that the connection was auto between the 2. This was fine at first as just needed one password tpo connect to hub3 and none of the choosing between 2.4 or 5 channels.
having had some dropouts recently the operator changed my Hub settings ( remotely )so that i now have the option of 2.4 or 5 channels again.....now do i have to reset the passwords again for all devoices that want to connect to hub....it seems so...
16-09-2022 09:36 - edited 16-09-2022 09:37
You would have had one wi-fi SSID before (along the lines of VM123456) and one password.
If VM CS has split the wireless bands you will now have two different network names, one for each wi-fi band.
Your password might be the same as before for both the new SSID.
So you will need to reconnect your devices to the new network which they require (either the 2.4GHz or 5GHz name).
on 16-09-2022 09:40
i thought having one SSID was the benefit of a Hub 3 ?
on the Hub 2Ac i did have 2 SSID and a device would connect to whichever one it had the password for.
Initially the Hub3 only had one SSID.....so a device would connect to the best signal automatically ?
Im not sure of the benefit of having2 SSID's again ?
on 16-09-2022 09:41
on 16-09-2022 09:47
16-09-2022 09:48 - edited 16-09-2022 09:52
@dazzabird wrote:
if i make both bands the same password will a device swich between the 2 as needed depending on the best signal
You have two separate wi-fi networks now, so you would need to go through the process of connecting the device to each network separately (the 2.4GHz version and the 5GHz version). They can have the same password or a different password but you need to make two separate connections now for your device.
Once you have done that, the device will be able to connect to both (assuming that the device itself has dual band capabilities). The device usually just selects the strongest signal (which is often 2.4GHz which is not as fast as the 5GHz signal).
(Edit: Missed replies at #3 to #5 while typing the above so up to you which option/config you want to use. If you have any of the VM pods I believe they require a combined SSID)
on 16-09-2022 10:03
on 16-09-2022 10:03
on 16-09-2022 10:15
16-09-2022 10:18 - edited 16-09-2022 10:19
@dazzabird wrote:
will my wifi pods be affected by this
I've never seen/used the VM pods so someone else will have to help you here but I think they need the SSID to be a combined one. Wait for someone else to chip in an help you with this with the correct advice.
VM pods (if that is what you have) are these things
https://www.virginmedia.com/broadband/intelligent-wifi
Edit: Crossed post again with BenMcr
