Mohamed004
  • 9
Message 1 of 16
Help I couldnt find virgin media's omnibox and wall socket on my house,what should i do?
Hi virgin media community
I am new at virgin media i made my order yesterday friday and it suggested me self install, couldnt find an omnibox and a wall socket, i did find a small virgin media socket and a virgin media wifi/password sticker
I also followed the small sockets cable
 And let me outside
 And there is nothing here
There most have been a previous virgin media customer, only a small socket of virgin media is in the house, my order will arive at 13/4 what should i do?
Anonymous
Not applicable
Message 2 of 16
Re: Help I couldnt find virgin media's omnibox and wall socket on my house,what should i do?
its the connection in the 3rd image
Mohamed004
  • 9
Message 3 of 16
So later how should i connect, i did see that it requires a wall socket to connect on. Could you tell how?               Thanks
Anonymous
Not applicable
Message 4 of 16
disconnect the bottom screw connection and connect to that.
That isolator is what would normally be in the wall box that has been removed
Mohamed004
  • 9
Message 5 of 16
Thank for your time and thank for your help, i will try on that after my order has arrived 👍
Anonymous
Not applicable
Message 6 of 16
lets us know how you get on
  • 2.92K
  • 221
  • 624
Trouble shooter
Message 7 of 16
<snip> 
The thick white cable that is connected to the old isolator. Where does the other end go to ?  You may be able to connect your quickstart kit to that end as an alternative.
BrianY
  • 701
  • 23
  • 107
Rising star
Message 8 of 16
Can anyone see an exterior cable box, looks clean from here?
Mohamed004
  • 9
Message 9 of 16
 This is the end of the thick white cable it was not connected on anything, is it possible for me to connect this end to my quickstart kit?
Anonymous
Not applicable
Message 10 of 16
you can connect that into the hub but if you have a splitter cable for tv as well that will not work
