on 23-10-2021 12:10
Following a hedge trim, my broadband cable is now fully exposed. Can this be hidden?
on 23-10-2021 12:30
Yes, you can bury this down so you can't see it
on 23-10-2021 15:10
@nigeltaylor wrote:Following a hedge trim, my broadband cable is now fully exposed. Can this be hidden?
Usual suggestion on here is to post up some photos of the problem so the VM forum team can assess and advise. VM may well send someone to remedy it but the default VM approach generally involves no more than burying the cable a few inches below the surface or leaving the cable on the surface inside a green plastic conduit.
Depending on your view on either of those two likely VM methods, you might want to DIY as has already been suggested.
on 25-10-2021 15:58
Hi @nigeltaylor,
Welcome to the community and thanks for taking the time to post here on our forums.
I'm sorry to hear of the problems with your cabling, we can arrange for this cable to be reburied but would need you to confirm a few details via a private message.
Please look out for the private message and we can get started.
Regards,
Steven_L
