on 18-09-2021 16:33
My wifi works but anything I connect via Ethernet cable cannot connect to the internet. I have tried several devices with several cables, I have also tried following guides online and a pin hole reset does not work, I suspect there is an issue with the hub but none of the options on the website anticipate this as an issue so it sends me round in circles. How do I speak to a person or request an engineer?
18-09-2021 17:04 - edited 18-09-2021 17:05
This a paste of a post made by VIP -Tudor - some time ago.
_________________________________________
You can test the cable and/or if the Hub ports are working ok, by doing this. Plug an Ethernet cable into two of the ports on your hub, the LEDs in the connectors should flash if it’s ok. Try on all ports and with all of the cables you have. It’s unlikely, but possible, that several cables are faulty. If no LEDs flash when testing both cables I would expect the problem lies with the hub. Do a pin-hole reset for 60 seconds and the hub will restart, do NOT power cycle the hub. After a few minutes retry the tests above.
If no LEDs light, call customer services and report the faulty hub.
on 18-09-2021 17:21
Just tried this, I am getting a solid light when I connect the Ethernet cable at both ends but still no internet connection through Ethernet. Is there a number I can call that will not send me into an infinite bit loop?
on 18-09-2021 17:31
on 20-09-2021 17:52
Hi 03kerfr, thanks for the message.
I have looked into this and cannot see an issue as everything is showing as green, can you confirm what was advised on the last call and if the issue is still present?
Chris
