on 25-11-2021 20:19
Keep getting drop outs and dropped connections, doing my head in 😞
Acquired Downstream Channel (Hz) | 202750000 | Locked |
Ranged Upstream Channel (Hz) | 46200000 | Locked |
Provisioning State | Online |
25/11/2021 20:13:7 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/11/2021 12:41:6 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/11/2021 12:03:52 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/11/2021 07:08:13 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
Network access | Allowed |
Maximum Number of CPEs | 1 |
Baseline Privacy | Enabled |
DOCSIS Mode | Docsis30 |
Config file | cmreg-vmdg505-bbt053-b.cm |
SFID | 3306 |
Max Traffic Rate | 575000000 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
SFID | 3305 |
Max Traffic Rate | 38520000 |
Max Concatenated Burst | 16320 |
Scheduling Type | BestEffort |
on 04-12-2021 10:08
Hi Mathew,
Thanks for reaching back out, how are things now, I have done some checks our end and everything is looking in the green, no errors or area issues, if you are still facing issues please let us know and I will be happy to help further?
Paul.
on 04-12-2021 14:33
Is the test directly on my line? Ever since I had in installed my ping has been like 18 25 29 20 29 constantly changing non stop every day. It's not stable, every so often it's spiking to 300s. The only thing I can guess, is when the installer came when we moved in, he used an old wire sticking out the wall that had been there a long time, instead of installing new cables etc. Could this cause ping instability and video game connection drop-outs?
on 06-12-2021 13:19
on 06-12-2021 13:21
on 08-12-2021 13:37
Good Afternoon @mattewmoore123, can you please update us on the status of the services?
Are the connection issues restricted to Wi-Fi?
The stats of the hub are within spec, but it does appear that there may be some issues with a Wi-Fi connection.
Do you have any devices close to the hub that could be connected via an Ethernet cable?
Kindest regards,
David
on 08-12-2021 15:53
Currently okay David,
But the ping spikes randomly happen and I'm not sure how your ping spiking to 300 ms is within spec or how your ping never ever sitting at like a stable number for more than 3 seconds is in within spec either,
I suspect this is caused by the installer choosing to use an old cable in the wall rather than have to add anything to the property at all,
There were no additions of faceplates or wires inside or out whatsoever, he just used an existing cruddy co-aux cable that looked like it's been there since the 90s,
Is it my best bet to call Virgin and ask them to have an installer re-do/check it?
The gentleman was very nice, however, it was during the lockdown and he was very keen to do as little as he could and leave as soon as he could, understandably as it was peak lockdown.
Thanks.
on 10-12-2021 16:04
I'm sorry to hear this @mathewmoore123
Our checks do monitor the connection directly to the Hub rather than WiFi.
Can you clarify if the issues you are noticing are occurring on a WiFi or a wired connection?
If WiFi are you able to connect a device via an Ethernet and check the connection again?
Thank you.
