  • 5
CL2718
Message 1 of 12
Constant connection dropouts
Hi All,
I was just hoping someone could check over my logs and give any insight into what's happening to our connection.
Since Friday connection stability has been getting worse and worse, now we're having dropouts every 10mins at worse. These come in spats, with afternoons being particularly bad it seems.
Funnily I've noticed that if I'm using Discord when the connection drops I can still hear people speaking for a little time after everything else is broken, although they cannot hear me. Does this indicate some sort of Upstream issue?
From my limited knowledge it seems my signal and noise values are OK... However the logs show many T3 and T4 timeouts, though I'm unclear what they mean. If someone more experienced could check it out I'd appreciate it, logs to follow.
Cheers,
Chris
Channel
Frequency(Hz)
Power
(dBmV)
SNR
(dB)
Modulation
Channel ID
1
434250000
3.5
35.7
256 qam
4
2
594250000
0.7
36.3
256 qam
24
3
586250000
0.9
36.3
256 qam
23
4
578250000
0.7
36.3
256 qam
22
5
570250000
1
36.6
256 qam
21
6
562250000
1.4
36.3
256 qam
20
7
554250000
1.2
35.7
256 qam
19
8
546250000
1.5
35.7
256 qam
18
9
538250000
1.5
36.6
256 qam
17
10
530250000
2
36.3
256 qam
16
11
522250000
1.9
35.7
256 qam
15
12
514250000
2
35.7
256 qam
14
13
506250000
2
36.3
256 qam
13
14
498250000
2.2
35.7
256 qam
12
15
490250000
2.5
35.5
256 qam
11
16
482250000
2.9
35.7
256 qam
10
17
474250000
2.7
36.6
256 qam
9
18
466250000
3
35.7
256 qam
8
19
458250000
3
35.5
256 qam
7
20
450250000
3.2
35.7
256 qam
6
21
442250000
3.5
35.5
256 qam
5
22
426250000
4
35.7
256 qam
3
23
418250000
4
35.5
256 qam
2
24
410250000
4.6
35.7
256 qam
1
Channel ID
Frequency(Hz)
Mode
Power
(dBmV)
Modulation
Channel Bandwidth(Hz)
Symbol Rate (ksps)
19
32600000
ATDMA
35.3
16 qam
6400000
5120
17
46200000
ATDMA
35.3
16 qam
6400000
5120
Date And Time
Error Number
Event Description
2018-07-09 12:34:15.00
82000400
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;
2018-07-09 12:34:56.00
82000200
No Ranging Response received - T3 time-out;
2018-07-09 13:01:39.00
82000400
2018-07-09 14:12:27.00
82000200
2018-07-09 14:56:10.00
82000300
Ranging Request Retries exhausted;
82000600
Unicast Maintenance Ranging attempted - No response - Retries exhausted;
2018-07-09 14:56:13.00
82000200
2018-07-09 15:10:32.00
82000400
2018-07-09 15:17:27.00
82000200
2018-07-09 15:21:46.00
82000400
2018-07-09 15:22:39.00
82000200
2018-07-09 15:33:11.00
82000400
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-
2018-07-09 15:40:11.00
82000200
2018-07-09 17:59:41.00
82000400
2018-07-09 18:00:23.00
82000200
2018-07-09 18:07:42.00
82000300
82000600
2018-07-09 18:07:44.00
82000200
2018-07-09 19:56:03.00
82000400
2018-07-09 19:56:46.00
82000200
  • 56
  • 8
zhen7
Message 2 of 12
Re: Constant connection dropouts
I’ve been getting the exact same since Friday evening when a new Softwate Auto Update was pushed to my hub.
Never had any disconnections in almost 3 years at my new build property until them.
Im getting exactly the same Logged Error as you too.
My only issue was my Hub was only connecting to 1 Downstream Channel instead of 4 making it even worse as the 1 Channel had a power level of 58.
Ive had a text to say Virgin saw this as a area problem and engineers have now fixed it. I will test it later when I get home.
  • 6.22K
  • 481
  • 1.03K
Hero
Message 3 of 12
CL2718 - your stats are ok. Possibly noise on your circuit causing the T3 and T4s, call customer services and they can check out your circuit and get a technician out to you if required.
zhen7 - same goes for your connection. It’s best to raise separate posts as they may well look the same, but be entirely different.
  • 5
CL2718
Message 4 of 12
Thanks for your help Tudor, I think it's great that there's a community such as this with knowledgeable people who are willing to check things.
I'll give them a call (I have noticed a Virgin Media van in the village today so they may be aware!), just wanted to know if I was on the right track before I did.
Cheers.
  • 10.32K
  • 281
  • 591
Forum Team (Retired) Emma_E
Message 5 of 12
Hi CL2718,
Welcome to the forums, I am sorry to see you have been having trouble with your connection.
I have taken a look and can see your SNR is on the low side. I have raised this to networks to investigate further.
I will let you know as soon as I know more.
Speak to you soon.
Emma
  • 10.32K
  • 281
  • 591
Message 6 of 12
Hi CL2718,
Just a quick update a fault has been raised ref F006383655 for low SNR the current review date is 25/07/2018.
Please give this thread a bump closer to the time and we will get an update for you.
All the best
Emma
  • 5
CL2718
Message 7 of 12
Hi Emma,
Thanks for raising a ticket for us, Currently our SNR is reading 37dB across the board.
I noticed some Virgin Media vans in the area just after the time of this original post, and since then I have not noticed any more disconnects.
The modem's Network Logs still show some "SYNC Timing Synchronization failure" errors, I'm not sure if this is important.
Are there any notes as to the resolution of Ticket F006383655 ?
Many thanks
  • 5
CL2718
Message 8 of 12
Hi Again.
Issues are back, I notice that today is extremely hot... as it was last time this was happening... might not mean anything.
Log is:
Time
Priority
Description
2018-08-04 13:53:04.00
Warning!
RCS Partial Service;
2018-08-04 14:22:09.00
critical
SYNC Timing Synchronization failure - Loss of Sync;
Warning!
2018-08-04 14:22:10.00
critical
2018-08-04 14:22:15.00
Warning!
Lost MDD Timeout;
2018-08-04 14:22:38.00
Warning!
2018-08-05 13:00:37.00
critical
2018-08-05 13:00:38.00
Warning!
critical
2018-08-05 13:00:43.00
Warning!
Lost MDD Timeout;
2018-08-05 13:01:18.00
critical
Warning!
2018-08-05 13:05:18.00
critical
2018-08-05 13:06:13.00
critical
2018-08-05 13:22:28.00
critical
Warning!
critical
Warning!
2018-08-05 13:22:32.00
Warning!
Lost MDD Timeout;
2018-08-05 13:23:05.00
Warning!
Downstream is:
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
434250000
3.4
37
256 qam
4
2
594250000
2.2
37
256 qam
24
3
586250000
2.2
37
256 qam
23
4
578250000
2.2
37
256 qam
22
5
570250000
2.4
37
256 qam
21
6
562250000
2.5
37
256 qam
20
7
554250000
2.2
37
256 qam
19
8
546250000
2.2
37
256 qam
18
9
538250000
2.4
37
256 qam
17
10
530250000
2.7
37
256 qam
16
11
522250000
2.7
37
256 qam
15
12
514250000
2.7
37
256 qam
14
13
506250000
2.5
37
256 qam
13
14
498250000
2.5
37
256 qam
12
15
490250000
2.9
37
256 qam
11
16
482250000
3
37
256 qam
10
17
474250000
3
37
256 qam
9
18
466250000
3.2
37
256 qam
8
19
458250000
3.2
37
256 qam
7
20
450250000
3.2
37
256 qam
6
21
442250000
3.4
37
256 qam
5
22
426250000
3.7
37
256 qam
3
23
418250000
3.9
36
256 qam
2
24
410250000
4.4
36
256 qam
1
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
37.3
40
0
2
Locked
38.6
65
0
3
Locked
38.6
51
0
4
Locked
37.6
71
0
5
Locked
38.6
70
0
6
Locked
38.6
58
0
7
Locked
37.6
71
0
8
Locked
37.6
63
0
9
Locked
38.6
62
0
10
Locked
37.6
49
0
11
Locked
37.3
45
0
12
Locked
37.6
49
0
13
Locked
37.6
48
0
14
Locked
37.3
45
0
15
Locked
37.3
31
0
16
Locked
37.6
35
0
17
Locked
37.6
33
0
18
Locked
37.6
20
0
19
Locked
37.6
29
0
20
Locked
37.3
24
0
21
Locked
37.6
25
0
22
Locked
37.3
33
0
23
Locked
37.3
39
0
24
Locked
37.3
24
0
Any help appreciated,
Cheers
  • 12.75K
  • 400
  • 730
Forum Team (Retired) Heather_J
Message 9 of 12
Hello CL2718,
Thanks for keeping in touch 🙂
I've just tested your network and I can see the fault has now been resolved. Any improvements since your last post?
Talk soon,
Take care.
Heather_J
  • 5
CL2718
Message 10 of 12
Hi Heather,
Thanks for your reply, this past week we have not noticed any disconnects.
The modem logs still show sporadic (once per day/2 days) 'SYNC Timing Synchronization failure' and 'No Ranging Response received - T3 time-out' errors.
I don't know if this is part of normal operation or not?
Cheers
