scottty87
Connection Issues! Flashing Green light of Doom!!!
Hi all.... new VM customer here after many many years! I have installed our hub and box as per the instructions but I can't seem to get past the flashing green light of Doom!
I have attached an image of the isolator cable going into the old wall box... maybe I'm wrong here????  Really hoping someone can point me in the right direction!!!
scottty87
Re: Connection Issues! Flashing Green light of Doom!!!
  • 6.23K
  • 482
  • 1.03K
Hero
I presume it’s a self install to a property that had VM installed previously. Have you phone VM to activate the Hub3? If so, there is a possibility that the cable has been disconnected at the street box. You need a technician to rectify, please call customer services.
scottty87
Hey cheers for the reply. Yes called them to get the Hub activated, everything seems connected correctly so as you say, must be disconnected at the street box.
VM are sending an engineer out on Tuesday to hopefully get us connected so not too bad, good service I must say. Really appreciated the advice!
  • 11.82K
  • 782
  • 3.48K
Just to back up Tudor, you need an Engineer. Which you have booked so cushty. Make sure they fit a proper wall outlet with isolator at the place the cable is hanging out of the wall....looks like the original has gone walkabout....
Click to learn more about VIP
Use Kudos to say thanks
  • 6.23K
  • 482
  • 1.03K
Hero
Yep, users here are ready to help or point you in the right direction.
