  • 97
cheetah
Connecting our HP wireless printer
We were forced to upgrade to a 3.0 Hub and a V6 box which we are confused about , is it a   Tivo or is it a V6 or both ? we just don,t know . We kept being reminded about the up-grade on our TV and the threat we would lose our services and then we received the dreaded letter confirming the threat .
So we reluctantly ordered the up-grade , there was absolutely nothing wrong with the equipment we have had for years it worked perfectly fine maybe a few glitches now and again but it was reliable .
And now we have this up-grade our HP printer will not connect were as before it work fine so what do we do ? we need our printer to work the old man prints a lot of work sheets for his job.
  • 15.64K
  • 1.63K
  • 3.52K
Re: Connecting our HP wireless printer
What have you done so far to connect the wireless printer?
Given the WiFi name on the Hub 3.0 is different than your previous Superhub, have you consulted your printer’s manual how to make this change, how to let the printer know the new SSID and password?
  • 15.64K
  • 1.63K
  • 3.52K
I’ll put this in here as well as on the thread with your duplicate posting. The model of your printer will determine which approach you have to take.
