andyswilson
Connecting Sony bravia tv to virgin tv box
Just bought a new sony bravia tv. I have connected up the virgin tivo box through the hdmi cable but when it comes to scan for services the tv can't find any. Tivo box is on and works fine with previous tv.
  • 26.23K
  • 1.11K
  • 4.32K
Re: Connecting Sony bravia tv to virgin tv box
you tv doesn't scan for channels. set the TV to the HDMI input
Click to learn more about VIP
Use Kudos to say thanks
  • 14.01K
  • 1.49K
  • 3.01K
You only need to scan for channels if you have a rooftop antenna connected to the tv & want to tune in the Freeview service.
Virgin uses an HDMI input the same as a DVD recorder. The Virgin box does the tuning not the TV.
Look for an "AV" or "Aux in" button on the TV remote (sometimes an arrow pointing into a tv screen) & select the socket the TV box is plugged into.
andyswilson
Cheers guys, got it now. I didn't check all the hmdi inputs. Thanks for your help.
