  • 3K
  • 167
  • 474
chenks
Trouble shooter
Message 11 of 16
Re: Connecting Sky box to Virgin Super Hub
no you don't need to do anything other than connect the cable.
the link says "Plug one end of the yellow or black Ethernet cable into the ETHERNET port at the back of your Sky box.
Plug the other end of the cable into one of the available ports at the back of your router.
Your Sky box should then automatically connect to your broadband."
  • 3K
  • 167
  • 474
chenks
Trouble shooter
Message 12 of 16
@happy37 wrote:
According to your link, I will have to go in to the settings page and put in the following:-
IP address - Virgin hub?
Subnet mask - 255.255.255.0?
Router - 192.168.0.1?
DNS servers - 194.168.4.100 or Google or whatever?
Please advise.
Thanks.
also, no idea where you are seeing that, as none of the steps on that page tell you to do that.
  • 7
happy37
Message 13 of 16
I'm seeing this on the Sky settings page in that link you mentioned.
  • 3K
  • 167
  • 474
chenks
Trouble shooter
Message 14 of 16
 well i'm not, as the link says, connect the ethernet cable and that's all you do.
  • 4.15K
  • 279
  • 695
Roger_Gooner
Community elder
Message 15 of 16
When you connect with the Ethernet cable it should take priority over WiFi, so it's simply a case of plug and play.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
  • 7
happy37
Message 16 of 16
Thanks to all of you who replied.
Rebooted the Sky box and the Virgin hub.
All is working now.
happy37
