Connecting Printer to Hub
lisa-marko
I’m trying to connect my HP printer to my WiFi but I can’t seem to find the required information?
I’ve got two options…
The PIN from the router label (8 digits)
or
The Network Security key
I can’t seem to find either of these on the hub?
Can anyone help please?
1 ACCEPTED SOLUTION
Accepted Solutions
This may be helpful
Virgin Hub 4 - No WPS Pin option - Virgin Media Community - 4911135
It's not clear from the thread whether this was a solution..
8 REPLIES 8
Ernie_C
I guess the ‘network security key’ is the WiFi password.
Thanks for the reply, I’ve tried that and it doesn’t recognise it 😤
I’ve tried all the numbers but to no avail, I was hoping someone might have had a similar issue and point me in the right direction.
Have you connected any other wireless devices?
It will be the same password/key you used.
If it doesn't work then there could be a compatibility issue.
My laptop, tablet and phones are fine, maybe it’s a problem with the printer then 🤷🏼‍♀️
Depending on the model of printer it may not work very well with the 2.4 and 5Ghz bands as on network name (SSID).
There are several threads on here regarding splitting the bands that can sometimes help.
Bolehill
Dialled in
What model of printer is it Lisa?
It’s a HP Deskjet 2633
This may be helpful
