on 31-01-2022 13:54
I’m I doing something wrong?
on 31-01-2022 13:57
thats not a VM wall socket just a standard aerial connector
not all installs have an internal box
start outside and look for the external wall box - 6" square ish usually on wall facing road or pavement - brown or grey usually - follow any cables that come from it and go inside - if there are non look inside opposite external box as they may just have drilled through wall - as said it may just be a cable rather than an internal wall box
if you find a cable you need one of these to attach the cable that came with the quick start kit
https://www.diy.com/departments/tristar-data-cable-coupler/571706_BQ.prd
on 31-01-2022 14:04
I live on the top floor of a flat so not sure where to look. I’ve checked everywhere and there is also a white box with SAT1 and SAT2.. I’ll attach a pic. Does this look right?
on 31-01-2022 14:11
that looks like Sky to me but try them - if the hub light goes white after a few minutes you are getting there - if it stays grren - solid or flashing thats not good
if they have allowed self install the address has had VM in the past but cables may have been removed or cut - have a good search one a while ago had the cable box behind a radiator
on 31-01-2022 14:20
No luck with the others, I’ve just found this but doesn’t seem to fit either.
on 31-01-2022 14:27
hard to see what it is - can you get a better picture of the end
on 31-01-2022 14:30
on 31-01-2022 14:45
Could possibly be a VM connection, but you would need an F to F F-type connection to join the cables.
on 31-01-2022 14:50
as tudor says and i say above
but before you do that there looks as though there might be enough cable there to connect the hub up and test the connection - if it works and you are happy with the hub there then get the connector above and you are up and running - if it does not work you need a tech
even if it works and you dont want the hub there just book a tech and say its not working - just leave it disconnected when you ring - makes it easier to book the tech - then just tell the tech where you want it when he turns up
on 31-01-2022 16:26
Thanks for the help, I tried connecting but it wouldn’t fit so I’ll go with your suggestion on trying a tristar. If all else fails I’ll get in a VM tech. Thanks again!
