mojo1981
Message 1 of 11
Cable not buired / installed correctly below driveway
I purchased the house three months ago, i decided to get virgin media installed, installation was done but I have noticed the green virgin media cable is not buried underground below the driveway, it is above and can easily be cut or damaged, I am not happy about this as it should have been installed correctly under the driveway in the first place? what can virgin media advise as I have seen people pulling on it as they walk past my house and it can be easily cut from outside were it has a cover over it but sticks out the brickwork, the house or in the driveway i have pictures that can help to explain. The cable is bright green and unsightly and ruins the appearance of my driveway any suggestions or help would be great thank youp1.jpgp3.jpgp5.jpgp7.jpg
mojo1981
Message 2 of 11
Re: Cable not buired / installed correctly below driveway
  • 3.65K
  • 201
  • 608
chenks
Community elder
Message 3 of 11
virgin won't and don't install under driveways that are tarmaced or paved. it's only ever dig into loose ground and covered.
the green you are seeing is not the cable, that is the plastic protective conduit. the cable is inside that.
can't comment any further until photos are visible.
  • 14.12K
  • 1.51K
  • 3.04K
Message 4 of 11
In most cases like this I would expect the cable to be clipped to the wall. I’m surprised they have trunked it along the ground like this. Certainly they will not lift block paving. The occupant would have to arrange for this to be done by a third party.
Click to learn more about VIP
Use Kudos to say thanks
  • 439
  • 28
  • 42
Message 5 of 11
Hi mojo1981
Welcome to our community and thanks for posting.
May we ask if you discussed the options of burying the cable with our technician before we installed our services?
If you would like us to get a technician to return to the property and asses what alternative route we can use we can do this for you.
Please let us know if you would like us to attend.
Thanks Jodi
  • 20
Jonny-M
Message 6 of 11
It reads like you just noticed this giant length of green conduit on top of your block paving - was it covered up by leaves before or something?
The quickest thing here is going to be to get some clips and attach it to the wall yourself after cutting off the conduit. Presumably you signed off on the original installation so I think you’ll be waiting a while for VM to do anything about it.
  • 3.65K
  • 201
  • 608
chenks
Community elder
Message 7 of 11
the important thing for the OP to note is that virgin will not dig up the driveway paving and put it under there.
they only ever dig trenches in loose soil/dirt/grass.
  • 6.25K
  • 482
  • 1.03K
Hero
Message 8 of 11
It’s up to you, the customer, to ensure any work done is correct and any problems discussed BEFORE the technician leaves your premises. Complaining afterwards is not the way to get satisfaction.
  • 4.74K
  • 319
  • 796
Roger_Gooner
Superstar
Message 9 of 11
Be glad that there is a conduit, some installations are just bare cable.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
  • 3.47K
  • 111
  • 417
VMCopperUser
Trouble shooter
Message 10 of 11
Not enough length left on that to put it under the bricks.
I would remove the green ducting and clip it to the wall.
In the past they would lift some flags, but you would be hard presses to get them to lift that many bricks and put them back!
I do not work for VM, but I would. It is just a Job.
Most things I say I make up and sometimes it's useful, don't be mean if it's wrong.
I would also make websites for them, because the job never seems to require the website to work.
